rotor fin direction ?
Old Jan 26, 2005 | 03:50 PM
88sk's Avatar
88sk
Default rotor fin direction ?
gotta a set of drilled& slotted rotors off ebay,stopchek is the vendor,1 rotor, rightrear cooling fin leading edge is goin forward compared to the other 3 ,the stock ones also had the top edge follwing the bottom when goin forward ,will the 1 rotor run hotter or wont it matter ?
Old Jan 26, 2005 | 04:20 PM
allanlaw's Avatar
allanlaw
The fins should move air from the inside of the rotor to the outer edge when the car is going forward, so top edge follows bottom edge
Old Jan 26, 2005 | 04:22 PM
Mighty-Mouse's Avatar
Mighty-Mouse
In street driving it's not that big a deal. But on the track you will see 10-15% higher temperature on the rotors going in the "wrong" direction.
I'm assuming you have typical curved vanes, not straight vanes or island vanes.
Old Jan 26, 2005 | 04:23 PM
AU N EGL's Avatar
AU N EGL
Rotors are directional. If they are not installed on the proper side of the vehicle, airflow will be restricted and cooling will be severely diminished. The vanes on a rotor act like a centrifugal air fan, drawing air from the inside of the rotor and flowing it to the outside. The vanes of a directional rotor should arch back like arms on a pinwheel. On the top side of the rotor, the vanes should curve toward the back of the car.
http://www.stoptech.com/faq/data/faq16.html
HTH
Old Jan 26, 2005 | 04:24 PM
AU N EGL's Avatar
AU N EGL
Dohh :o beat to the post.
Old Jan 26, 2005 | 04:33 PM
Mighty-Mouse
Let me add that the 10-15% number is at moderate track temperatures.
As the heat rises the differential gets larger. So if your really stressing the brakes the "wrong" rotor can get much hotter than the others.
Old Jan 26, 2005 | 04:45 PM
88sk's Avatar
88sk
excellent photo's,they are curved like the stock ones ,I just called the vendor& he called me back & said it wouldnt matter much,dont know if its a concern as its just street driven.
Old Jan 26, 2005 | 09:32 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Ask him if it matters if you pay the full amount! Tell him to send you the right part and a prepaid shipping label to send the wrong one BACK to him.
To rotor fin direction ?
