Blinkers stop randomly.
Old Jan 27, 2005 | 06:34 PM
123cya's Avatar
123cya
Default Blinkers stop randomly.
Just bought an 01 c5 and randomly the blinkers will stop working, any idea what this might be? Could be completely random but i gassed it to get on the interstate and it worked again......
Graham
Old Jan 28, 2005 | 12:10 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The emergency flasher botton and the relay behind it is probably starting to go bad. Sometimes you can bump the dash just above the switch and it will work again! Try pushing the flasher switch a few times to see if that helps.
BC
Old Jan 28, 2005 | 08:37 AM
professorhp's Avatar
professorhp
It's for sure the hazzard switch. It happens to mine and the temporary fix is to push the hazzard button, on and off.
Good luck.
PHP
Old Jan 28, 2005 | 10:57 AM
PRIMAL's Avatar
PRIMAL
Good luck.
PHP
Had mine fixed last year . It drive me nuts.
Old Jan 31, 2005 | 03:26 PM
C54DAZ's Avatar
C54DAZ
BTW You can change this by pulling the radio instead of the dealer charging you to pull out your dash if you decide to fix the switch.
Old Jan 31, 2005 | 03:28 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
BC
One good thump on the dash should get them working.
If not sometimes it can be the stalk on the steering column.
Old Jan 31, 2005 | 03:35 PM
SDWYZ C5's Avatar
SDWYZ C5
I replaced mine this weekend. I got mine from "valvegod". He is the greatest to deal with.
Here is the link to my post.
http://forums.corvetteforum.com/showthread.php?t=983597
Easy install. Just remove center dash trim and radio, instead of the whole top of the dash.
Old Jan 31, 2005 | 04:20 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Change your blinker fluid.
To Blinkers stop randomly.
