Voltage dropping while reving
Old Jan 30, 2005 | 05:58 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
Default Voltage dropping while reving
Ok, I need som advice. When I rev the car and the rpm's come down, the car shutters and the voltage drops down to around 10 volts. Also when the car shutters, my rpm's drop down to around 400-500. The car is a 97 6mn.
Old Jan 30, 2005 | 06:25 PM
dpd's Avatar
dpd
dirty throttle blade/housing
Old Jan 30, 2005 | 06:39 PM
boblackhardtop's Avatar
boblackhardtop
Had the same problem, turn out to be a bad connection at the battery terminal.
Old Jan 30, 2005 | 07:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Seeing as you have a 97, it may be a good idea to check ALL of your chassis grounds. My 98 gave me FITS and it turned out to be bad/corroded chassis grounds!
Here is my post on cleaning the chassis grounds!
It has helped numerous other forum members solve some weird electrical problems!
http://forums.corvetteforum.com/show...al+information
Make sure that you clean your battery terminals and make sure that they are torqued on the battery properly (11 ft/lbs)
Please let me know if you have any questions.
Bill Curlee
Old Jan 31, 2005 | 04:38 PM
raidersfan's Avatar
raidersfan
thanks, i will spend some quality time with the vette this weekend.
Old Jan 31, 2005 | 04:52 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Bill Curlee
Good advice it worked for me!
Old Jan 31, 2005 | 04:53 PM
raidersfan's Avatar
raidersfan
devo, did you have a problem similar to mine?
To Voltage dropping while reving
