Windshield Washer Fluid Low???
Old Feb 2, 2005 | 07:49 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Default Windshield Washer Fluid Low???
the DIC says it is low... but the tank is full??? What is the fix & What is the cost?
Old Feb 2, 2005 | 08:16 PM
pops98's Avatar
pops98
My 98 did the same thing. I bought a new washer level switch, not a big deal to install. Make sure you drain your washer tank, I used a turkey baster to get the liquid down, and on the rear of the tank is a switch that just pushed in. The part number is 22110978 and is listed as just indicator. Hope this helps, and the price was 45.69
Old Feb 3, 2005 | 02:38 PM
BayouVette's Avatar
BayouVette
i had same problem. Then one day when filling up I noticed the plug was loose.
It was full when I filled it but plug came loose when I was driving..
Sounds stupid, but it was the problem
Old Feb 3, 2005 | 04:04 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
you could check with Gene at karshop instead of going with a new one
Old Feb 3, 2005 | 05:43 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Wow, you gotta love this forum!
Old Feb 3, 2005 | 06:47 PM
Old Rotor Head's Avatar
Old Rotor Head
I had this happen after I pulled the tank for cleaning. Forum member told me I probably had the sensor upside down. The connection clip goes down, opposite of what I would have thought. Turned it over problem solved.
To Windshield Washer Fluid Low???
