Help with new CODES please
Old Feb 3, 2005 | 05:01 PM
zeusoftexas's Avatar
zeusoftexas
I have the same problem. Same codes. I have taken almost every connection I can find appart and cleaned, it has not helped. Has anyone out there solved this problem?
Old Feb 3, 2005 | 06:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your problems could be a number of things but I would start with the simple things first.
Please amswer these questions.
How old is your battery?
What mods do you have?
Do you have a front or rear mounted EBTCM (electronic brake traction control module?
If your battery is weak or the connections are dirty it can cause you to have random codes. More than likley you have dirty chassis grounds
The EBTCM has its own ground and I need to know if is fron or rear mounted to tell you where the ground is located.
BC
