Oil recommendation
Old Feb 4, 2005 | 03:27 PM
sirsenna's Avatar
sirsenna
Default Oil recommendation
Do C5s absolutely need synthetic? Or can I run standard 5W-30?
Denis
Old Feb 4, 2005 | 03:40 PM
Dave68's Avatar
Dave68
Synthetic ONLY!
Old Feb 4, 2005 | 03:42 PM
Racie's Avatar
Racie
Old Feb 4, 2005 | 03:43 PM
2KREDVert's Avatar
2KREDVert
Denis
You could run a dino oil but synthetic is better.
Old Feb 4, 2005 | 03:44 PM
Oldvetter's Avatar
Oldvetter
Synthetic oil was specified so no oil cooler was necessary (probably other reasons also). The LS1 has some small oil passages and synthetic flows better.
I use Mobil 1 synthetic in all my 5 vehicles. Excellant wear protection, better mileage, and excellant low temperature flow.
If you have a $45,000+ Corvette and they specify synthetic oil, why wouldn't you use it ? (sorry but I really don't understand your question).
Old Feb 4, 2005 | 04:05 PM
ALLEGRO's Avatar
ALLEGRO
Old Feb 4, 2005 | 04:54 PM
sirsenna's Avatar
sirsenna
Well... my 98 isnt $45000... plus I just got it... first oil change.
It was a valid question
Thanks for the tip...synthetic it is...
Denis
Old Feb 4, 2005 | 05:26 PM
vettenuts's Avatar
vettenuts
See you are in NB. Look around for some Castrol 0W-30, Made in Germany. Excellent oil and readily available in Canada. I have had excellent results with it as have many others. Check out this link for some good oil information.
Oil Forum
Old Feb 4, 2005 | 06:11 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Denis
Not sure what the 98 owners manual says, but my 2002 Z06 owners manual states:
"Your vehicle's engine requires a special oil meeting GM Standard GM4718M. Oils meeting this standard may be identified as synthetic. However, not all synthetic oils will meet this GM standard. You should look for and use only an oil that mees GM Standard GM4718M."
AMSOIL markets several grades of oils that meet GM Spec 4718M:
AMSOIL Series 2000 Synthetic 0w30
AMSOIL SAE Synthetic 5w30
AMSOIL XL-7500 Synthetic 5w30
As a note, I picked up a bottle of the "German" Castrol mentioned above, and while I have no doubt that it is a good oil based on test results I've seen, the bottle doesn't list GM Spec 4718M on it, nor does Castrol's product data sheet on their website.
P.S. AMSOIL sales vial the link in my sig or to the left benefit my Corvette race team and this website. Thanks.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 4, 2005 | 11:07 PM
2KREDVert's Avatar
2KREDVert
Another great oil is Kendall. Most machinists recommend it because they know the wear properties.
Old Feb 4, 2005 | 11:48 PM
66427-450's Avatar
66427-450
Oil Forum
i second that !
Old Feb 7, 2005 | 11:41 AM
mountainmotor's Avatar
mountainmotor
Denis
Just a tip . Look into the new Mobil Extended Performance Synthetic . It has even more anti-wear and other additives than regular Mobil1 and currently is just 50 cents per quart more money . It's only been available for a couple weeks now .
http://www.mobiloil.com/USA-English/...rformance.aspx
The Mobil 0w-40 Euro Car Formula Synthetic is one STOUT oil meeting both GM-LL-025-A and GM-LL-025-B specs among a long list of other specs. Thats a " up too " two year service spec BTW for 5 bucks a quart @ Autozones .
That oil will work very very well for you and is the factory fill for Porsche and others like the 05 Viper .
Old Feb 7, 2005 | 11:55 AM
furio666's Avatar
furio666
How about royal purple isn't that the oil better
Old Feb 7, 2005 | 04:08 PM
dkdonkim's Avatar
dkdonkim
Denis
my previous car had 50k miles in a year with a lot of track times....well abused....opened up the engine for head change, and guess what, virtually no scratches or anything....no wear, period....even the shop owner got impressed....i am a firm believer of mibil 1 5-30w....
also, it is a cheap insurance too....
Old Feb 7, 2005 | 11:05 PM
C66 Racing's Avatar
C66 Racing
Mountainmotor,
Not trying to get into another debate with you as I really don't have the time...
But, the new Mobil 1 Extended Peformance oil does not meet GM Standard 4718M, nor does the Mobil 0w40 Euro Car Formula. A quote from another forum:
"I emailed Mobil this the response I got
Mobil 1 EP does not meet GM4718M. "
Old Feb 8, 2005 | 09:46 AM
mountainmotor
Originally Posted by Subdriver
Mountainmotor,
Nor should you be getting into one with me
Just razzin you there a bit but you keep harping this 4178 deal and you haven't a clue what it's about . I've asked you time again to explain the parameters of that spec and in your replies you disregard my question. I do know the spec but I'm not educating an oil saleman today . Please don't take that too hard but I'm of the opinon if you are throwing it out there as a sales tool, you should know exactly why your dissing non 4178 oils for engines out of warranty .
If an oil exceeds 4178 thats icing on the cake . Every oil I have ever recommended here @ Corvetteforum exceeds 4178 so your effort in using that spec as a Amsoil " selling tool " is a futile attempt with me , IMO .
BTW , Mobil submits ALL of their oil for actual API and ACEA testing to ensure the oils are up to task .
Please show me where Amsoil does this with 4178 . This street goes both ways .
Old Feb 8, 2005 | 10:16 AM
mountainmotor
I tell you what , I'll give in on GM4718M and what it is , but for a reason ...................
Googled from one of the gazzilion Amsoil sites on the web vs pulling out an SAE paper or API pdf .
"Most synthetics mention GM 4718M in their list of claims; that's the unique spec created by General Motors for Corvette oil. It's a high-temperature requirement that tolerates less oxidation (thickening) and volatility (boil-off) on a standard engine test called Sequence 111E according to engineer Bob Olree of GM Powertrain "
Thats actually Sequence IIIE . He He , show me a buck a quart 10w-30 dino that won't meet Sequence IIIE oxidative thickening and Noack these days .
Minimum Noack must be not more than 15 , oxidation not more than something like 246% thickening over new oil . Later I'll post the exact % thickening allowed . Noack is absolute .
Not much to brag about there .... huh ? They even use a GM V-6 test engine
Giminnee , I was off a bit . That test allows 375% thickening
http://www.swri.edu/4org/d08/GasTest...st/default.htm
Speaking of oil , I've got some Synergyn 3w-30 that needs changed . It has around 10 months and 11k miles on it . I'll catch it in a clean drain pan and use it in the work car for another 6 months or so
To Oil recommendation
Old Feb 8, 2005 | 05:13 PM
C66 Racing's Avatar
C66 Racing
I don't know what GM Standard 4718M specifies and I'm not sure that it really matters to me. And I disagree with your interpretation of the above statement. The above statement doesn't say GM4718M is a Sequence IIIE test, it says "tolerates less oxidation and volatility" on a standard Sequence IIIE test. To me that means GM4718M has some higher standard for oxidation and volitility and it is just tested using the method of the Sequence IIIE test.
I'd ask you in return that if it this standard was so easy to meet, then why doesn't Mobil 1 EP meet the standard? Mobil themselves have stated it does not meet this standard.
My opinion on this matter is fairly clear cut and I'm not trying to use it as a selling point for AMSOIL, though I don't think it hurts either.
My opinion, once again: My owners manual states in at least three places that the oil must meet GM Standard 4718M. That's not my standard, it is GMs. There are numerous oils that do meet this standard and they are labeled on the product data sheet that they do so.
If someone wants to use an oil that doesn't meet this standard, that is certainly up to them, but in my opinion, they should make that decision knowingly, not blindly.
Old Feb 9, 2005 | 12:07 PM
mackvest's Avatar
mackvest
Default super oil
http://www.neosyntheticoil.com/contents.htm
Old Feb 9, 2005 | 12:13 PM
mackvest's Avatar
mackvest
Default new web site
