bleeding clutch slave cylinder
Old Feb 5, 2005 | 01:25 PM
vette_33410's Avatar
vette_33410
Navigator
Default bleeding clutch slave cylinder
I want to replace the fluid in my clutch system. Any tricks doing this?
I plan to use a pressure bleeder attached at the master cylinder (the same way I plan on doing the brakes).
Is the clutch slave cylinder accessible?
thanks
Old Feb 5, 2005 | 03:59 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
The clutch slave is located where its very difficult to access. In other words it's a real PITA. I just suck the fuid out of the reservior and replace it with clean fuid every other month and that seems to be working fine for me. Unless you are having clutch issues, I would not go through the pain of trying to actually bleed the system.
Old Feb 5, 2005 | 04:21 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
a turkey baster works great.
Old Feb 6, 2005 | 04:43 PM
Z06ufgrad2002
I use a medical syinge. They are much better because to chance of it dripping oil is much less than the turkey baster method.
Old Feb 6, 2005 | 04:58 PM
silverz06vette's Avatar
silverz06vette
http://www.97vette.com/howto/clutchbleed/index.html
Its a PITA, but if your fluid is guiness in color do it and then change it in the reservoir every few months. More often if hard use.
To bleeding clutch slave cylinder
