Steering making a noise
Old Feb 6, 2005 | 10:34 AM
GerryInOrange's Avatar
GerryInOrange
Default Steering making a noise
I gather the search function is down, so here's my question.
Turning the steering wheel produces a continuous "rubbing" noise inside the car. It sounds like some lubrication is needed in the steering wheel area itself. Any thoughts?
Old Feb 6, 2005 | 10:46 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the simple stuff first. Fluid level correct, is the pully slipping when you turn the steering wheel?
I have a mechanics stephesoscope that I use to isolate noises. The same results can be obtained by using a 3/8" length of rubber vacuum line. Hold one end to your ear and point the other the noise area. You can localize the noise down to the exact area/componet.
Let us know what you find.
BC
Old Feb 6, 2005 | 12:28 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
There is an opening at the lower bearing where you can inject/spray some white lithium grease. This should eliminate that rubbing-groaning-squeaking type noise that occurs when the steering wheel is turned in either direction.
https://www.corvetteforum.com/techti...D=35&TopicID=1
Hope this helps.
To Steering making a noise
