Radio code
Old Feb 6, 2005 | 05:09 PM
rkhegler's Avatar
rkhegler
Default Radio code
Just changed my batter and need the radio code to reset it. I am the second owner of the car. It is a 99 FRC. Where is the code located?
Old Feb 6, 2005 | 06:05 PM
RCK1999's Avatar
RCK1999
I assume from your question that the head unit is now locked. The code would have been set by the previous owner. There is a really good tech tip that contains a relatively long process to re-set the code without having the pre-set code. Unfortunately I can't seem to get into tech tips now. Maybe someone else would have the procedure and be able to post it for you. If not, keep checking until tech tips comes back.
PS - if the face of the head unit does say "locked", DON'T mess with it until you get the procedure. You can "lock it up even tighter" by messing with it.
PPS - Maybe if you know the previous owner, you could ask him for the code.
Old Feb 6, 2005 | 06:08 PM
RCK1999's Avatar
RCK1999
I found it for you. Here you go:
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere). Procedure: 01. Turn the ignition ON (The radio displays LOC) 02. Hold down the Radio Presets 2 and 3 buttons for six seconds 03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step. 04. Press the AM/FM button 05. The radio display changes to another three-digit number. Write this number to the right of the first one. 06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05 07. Call 1 800 537 5140 08. Press 1 then # (pound). You’ll hear “Invalid Code, try again” 09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start) 10. Enter the number from STEP 6 then * (star) 11. Listen to the four-digit number and write it down. It will be repeated twice 12. Turn the ignition ON (The radio displays LOC) 13. Use the MN and HR buttons to enter the code from STEP 11 14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code. Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due). I verified it on an Y2K C5 with a locked radio - mine.
Old Feb 6, 2005 | 08:36 PM
rkhegler's Avatar
rkhegler
Thank you very much. I will give it a "go"!
To Radio code
