Vararam Measurement?
Old Feb 7, 2005 | 01:14 PM
vettenuts's Avatar
vettenuts
Default Vararam Measurement?
Looking for the inside dimensions of where the air filter installs into the Vararam upper lid. I want to research some other filter options. Anyone got the dimensions or can measure them easily?
TIA
Old Feb 7, 2005 | 01:20 PM
C5XTASY's Avatar
C5XTASY
TIA
I'd be very interested in what you find in filter options. Please let us know. Thanks.
Ed
Old Feb 7, 2005 | 01:40 PM
gorillavet's Avatar
gorillavet
The K&N Filter that fits the Vararam is part number 33-2522. This is made for a Triumph TR-7. I would really be interested in any other options out there. Please post if you find any. Thanks...
Old Feb 7, 2005 | 03:02 PM
Patches's Avatar
Patches
33-2522 Product Specifications
Product Style: Panel Air Filter
Height: 0.688 in (17 mm)
Outside Length: 16.75 in (425 mm)
Outside Width: 5.313 in (135 mm)
Filter Re-Oiling Amount: 0.7 oz (21 ml)
Top Style: Open
Weight: 0.9 lb (0.4 kg)
Product Box Length: 17.13 in (435 mm)
Product Box Width: 8.25 in (210 mm)
Product Box Height: 1.75 in (44 mm)
Old Feb 7, 2005 | 03:05 PM
vettenuts's Avatar
vettenuts
Does the K&M fit perfectly with the outer dimensions listed? There is an AC Delco equivalent but not sure if there is a direct comparison on size and fitment.
Old Feb 7, 2005 | 03:13 PM
Patches's Avatar
Patches
Mine "fit" initially but I eventually trimmed it a bit to get it to seat better. I currently run VaraRam's Baja filter.
Old Feb 7, 2005 | 06:11 PM
vettenuts's Avatar
vettenuts
So it sounds like the dimensions are a little too big? I have a Baldwin size chart, do you think you could get by with one that is thicker?
Old Feb 7, 2005 | 06:41 PM
Patches's Avatar
Patches
Not much thicker. The air box seal on the VaraRam is already taxed to the max with the 33-2522.
Old Feb 7, 2005 | 08:48 PM
NoNeck's Avatar
NoNeck
I just happen to have my VR2B new in the box sitting beside the desk here. If you need actual measurements, let me know.
Old Feb 7, 2005 | 08:51 PM
vettenuts's Avatar
vettenuts
Yes, inside dimensions of the top air box lid.
Thanks.
Old Feb 8, 2005 | 09:00 AM
NoNeck's Avatar
NoNeck
5 1/2" X 16 1/2" . The factory foam filter measures 17" long but compresses some whan installing. I'd stick closer to the 16 1/2" if looking for another type of filter that is more rigid than the foam. I did notice on the foam filter that comes with the VR2b that it just looks like the center foam element is just hot glued in. Maybe cut it out and install the center of a k&n the same way?
Old Feb 8, 2005 | 09:39 AM
Patches's Avatar
Patches
Here are a couple of shots of my Baja filter.
To Vararam Measurement?
