Drill Mod for Master line ??
Old Feb 10, 2005 | 02:26 AM
C54DAZ's Avatar
C54DAZ
Default Z06 parts
Iv called WCC AND LAPD about this and they both say if you use the new 2001 to 2004 Z06 parts it should work fine. You Think they would know! Are you sure about this???
Old Feb 10, 2005 | 04:56 AM
beef's Avatar
beef
got the file wow there are alot of restrictions.
now do i have to pull the tranny to get to the slave???
mecleod makes a line that will fit our master not sure if it has the restrictions???? anyone know???
Old Feb 10, 2005 | 05:02 AM
beef's Avatar
beef
what do u mean?? does the 2001 -04 have no restrictions? i think that gm would keep restrictions in the lines in all years.
Old Feb 10, 2005 | 09:39 AM
ericdwong's Avatar
ericdwong
DANG! I wish I knew about this 3 months ago when I was doing my major driveline surgeory! I only drilled out the ones I could get to..... ugh. But so far my car has been OK in terms of the lazy clutch pedal at high rpms. My slave did die and my clutch sunk to the floor though....
Old Feb 10, 2005 | 12:49 PM
dvandentop's Avatar
dvandentop
ttt
Old Feb 10, 2005 | 12:58 PM
SS930's Avatar
SS930
Are you saying the Z06 does not have the restrictions?
Also, please email me the doc please... THANK YOU!
fastcat@sbcglobal.net
Old Feb 10, 2005 | 02:06 PM
motoracer's Avatar
motoracer
May I get a copy as well soloracer@gmail.com
Old Feb 10, 2005 | 02:13 PM
dvandentop's Avatar
dvandentop
dvandentop@Msn.com too
Old Feb 10, 2005 | 03:38 PM
C54DAZ's Avatar
C54DAZ
Im getting ready to do a clutch on my car and s you know its a pain to do. I only want to remove the hole rear end torque tube and tranny once so I wanted as much info about this so I called around and they all say if you use the zo6 parts there is no drill mod. Lapd says everything they install clutches in gets the z06 parts. And no drill mod is performed.?????
Old Feb 10, 2005 | 03:42 PM
C54DAZ's Avatar
C54DAZ
Default Beef.
The 2001-2004 is a new design. Differant part numbers too.WCC And LAPD and MTI have told me to just use the new z06 parts.And there should be no problem????
Old Feb 10, 2005 | 06:29 PM
6Speeder's Avatar
6Speeder
I got the '02 Z06 slave and master, they definately had the restrictors.
Old Feb 10, 2005 | 11:36 PM
C54DAZ's Avatar
C54DAZ
Oh man! Ok.. you would think these people would know what they are talking about. I guess ill be taking mine apart tonight to check it out they are brand new sitting in box. Ill post what I find with exact part numbers.
Old Feb 11, 2005 | 04:48 AM
  #33
beef's Avatar
beef
nice guys o love how everyone is helping on this thread.... i called mcleod today but their tech dept is closed till mon. i want to see if the line they make can work with a stock master cylinder and if it has any restrictions.
Old Feb 11, 2005 | 08:19 AM
  #34
leaftye's Avatar
leaftye
Originally Posted by rwj383
I posted a How To post here about 3 yrs ago illustrating how to modify all restrictions, including the hard 90 degree elbow. I cant seem to pull up any of my posts from that far back, but if you email me and I will send you those pics.
Robert Judd / Gen 3 MS
Do you still have the old link to your post? If you do, it can be modified to work with the new software. Post the old link, and I'll fix it.
Old Feb 11, 2005 | 09:19 AM
  #35
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I have my stock '01 master w/ a new oem slave and a LUK stage-II. The best mod I ever made w/ my clutch was remove the return spring under the pedal. It's never come close to sticking since (not sure if the problems are related). I've never had high rpm hard shifting problems... never drilled anything out either.
Old Feb 11, 2005 | 12:59 PM
  #36
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Removing that spring will help. It's not a return spring though.
It is an assist spring, It helps pull the pedal toward the floor
I removed mine.
I have an '02 Z06 Slave in mine and it had the restriction. The lines are '00 so they had them also.
I drilled everything I could get to easily, and I have no problems. I'm not running the stock clutch though.
Old Feb 11, 2005 | 07:53 PM
  #37
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are actually 4 altogether (I said 3 in an earlier post).
I sent out an informative email w/pic tutorial to all those of you requesting such info. Should answer all questions raised here in this post. If someone could inform me how to post pics in a thread here I could do that, too.
Robert / Gen 3 MS
You will need to host your pictures on a site like Photobucket.com
Just register and add any picture you like to your folder. Under each picture that you save there will be three options to select. click on IMG http until it is highlighted, copy it and then paste it into your post
If I can do it ANYONE can
Bill
Old Feb 12, 2005 | 01:14 AM
  #38
C54DAZ's Avatar
C54DAZ
Took Brand new z06 GM slave cyl Part #89059282 apart And YES It does still have the restrictors in the 90 deg tube! So disreguard what I posted about using the new 2001-2004 zo6 parts. Makes me wonder about These shops Ive been talking too. Sorry for the bad info.
