Couple of items in your post. The NHTSA recall did NOT start until Jan. 2004. So any work that GM did to the car back in 2002 was done as a part of the predacessor program to the actual recall. GM had a CSP 01004 that they were using and trying to avoid the recall. It did some of the same steps that were actually done under the recall but the program was NOT implemented uniformly and the exact work done to your car under it, if the actual recall was not done again after Jan 2004, is questionable at best. Get a copy of the GMVIS and see if there was a later service done to the column lock system.
The removing or actual bypassing of the "spliced purple wire and relay mod" is only done to 99 and 2000 manual trans cars that the owner want to install a CLB. Just bypassing the relay with the jumper wire DOES NOT correct the Column Lock symptoms unless you are installing a CLB.
Here is a link to a thread that speaks in detail to the bypassing of the column lock relay in 99 and 2000 manual trans cars:
Scroll down to about post 13 and begin reading. The detail pictures in my post #15 in that thread were not available when I looked at it just moments ago because the site hosting the pictures was having problems. Hopefully the site will be back operational soon. You may have to try again later today or tomorrow to see those pictures.
There is a potential negative impact to the BCM if you do the bypass and DO NOT install a CLB. Namely the BCM is directly driving the column lock motor and it is possible to fry the column lock circuits in the BCM if the battery goes low when this mod is done.
And yes the jumper is a permanent step in that the relay head is NOT reinstalled.
If you are having column lock symptoms on your 99, I recommend that you install the LMC5 rather than a CLB. It does NOT require the bypassing of the Column Lock Relay and is IMHO a better solution at least for 99 and 2000 manual trans cars.
Lastly the MOST likely cause of the symptoms you are seeing is a weak or bad battery or loose or corroded battery connections including the one at the starter. I strongly suggest that you have the battery tested. The voltage across the battery posts with nothing else connected to the battery MUST be greater than 12.5 volts. If it is NOT greater than 12.5 volts then the electronics in the car will NOT function properly. This is particularly true of the column lock electronics. The car will start with 12.2 volts or less but the Column Lock Electronics will fail to function correctly. Having voltage after the car starts from the alternator does NOT help. That is because the column lock electronics does its thing BEFORE the engine starts. Voltage once the car starts is Too late to help. Try recharging the battery to full charge. A good battery at full charge will measure 12.7 to 12.9 volts or more. If you cannot charge the battery to at least 12.7 volts it is on its way out and needs to be replaced.
Thanks for the quick reply. I looked at the maintenance records that the previous owner gave me and I did see that a second service was performed by GM in 2005 that is coded 04006, so it looks like the "real" recall works was done that you mentioned in your post.
I have a sneaking suspicion that I did have an issue with low battery voltage because the problem occurred after I was sitting in the car listening to the radio that I had just installed. I had just installed a new receiver and spent almost and hour fine tuning the settings. It was after that when the problem occurred. I will give the battery a full charge, clear the codes, pull the fuses and try it again.
What is the LMC5 that you are referring to as a replacement for the CLB?
CLB = Column Lock Bypass. It's a device that plugs into the wiring under the drivers knee bolster in place of the lock motor connection. The column gets unlocked, then you unplug the lock motor connector that goes to the BCM and plug in the CLB connector in its place. The lock motor will never operate again so the column is permanently unlocked even with no key in the ignition. The CLB is installed to accept the lock or unlock command from the BCM and then respond back to the BCM with the required "completed" signal to let the BCM "think" that the column was locked or unlocked as commanded. Without the appropriate "completed" signal the BCM thinks there is a problem with the column lock system and if it thinks the column is locked when it should be unlocked, the BCM commands the PCM to enable fuel shutoff. The PCM then shuts the fuel off at the defined speed. The Recall service set the speed to 2mph. It is possible to set the speed to a high number with the proper tuning software (HP Tuners or EFI Live). With the lock motor disconnected when the column was unlocked you can never get stranded by a locked column, only by the fuel shutoff unless that is reprogrammed. One of the benefits of a CLB is that it is much more reliable (if properly installed) than the lock motor was at responding to the BCM commands so that you are FAR less likely to experience a fuel shutoff if you don't reprogram the fuel shutoff speed. MOST people that install a CLB do NOT have the shutoff speed reprogrammed and very, very few ever have fuel shutoff issues. Properly installed means removing the GM K Harness if one was installed and for 99 and 2000 manual trans cars, bypassing the Column Lock relay if the spliced purple wire and relay mod was don as a part of the recall service.
LMC5 = Lock Module C5. It is a fairly new approach (last 2 years) to bypassing the lock motor. Rather than leaving car wiring between the BCM and the CLB, the LMC5 connects directly to the BCM. It does much of the same process, namely responding to the BCM when lock or unlock commands are issued by the BCM. It is claimed to be simpler to install than a CLB and given the unknowns of what may have been done by the dealer Techs or previous owners to the column lock system, it probably is. For a CLB to be properly installed you MUST disconnect the GM K Harness that MAY have been installed before plugging in the CLB. For a CLB on 99 and 2000 manual trans C5's you also need to bypass the Column Lock Relay. For the LMC5. since you disconnect and reconnect wires right at the BCM you don't need to know what may have been done by GM Techs or previous owners as the car wiring is left intact but disconnected. The down side if there is one to the LMC5 is that there are 3 different variations to the product, LMC5, LMC5-R and 5 wire LMC5. Apparently this is necessary because some C5's do not respond 100% correctly to the base LMC5 that everyone starts with. Some C5 with the base LMC5 installed continue to get the "Pull key..." message when they start the car. The good news is that the vendor is very good to work with. Call them and explain your issues and after insuring you correctly installed the product they send you the LMC5-R to try. If that still doesn't work, call back and you will get the 5 wire LMC5. I have not heard of any cases where the 3rd product doesn't completely bypass the column lock system.
The 99 and 2000 manual trans cars are the worst to deal with on Column Lock problems but even those can be made to work with either a CLB or LMC5.
Without one of these two aftermarket solutions it is just a matter of time untill a C5 that can experience the column lock symptoms does experience them. Worst is when the car is NOT close to home where you can work on the issue without getting taken by a Stealership. GM has NEVER had a permanent fix for the C5 column lock symptoms and anything a stealership does for repairs to the column lock system WILL fail again.
I have the LMC5 on order. It should show up in a day or so. I will let you know how it goes once I install it.
I installed the LMC5 earlier this week and it works PERFECT!!!! Resolved my issue. Richard at Compliance Parts was very helpful and knowledgeable on the phone. I would highly recommend that anyone dealing with this issue purchase the LMC5 from Compliance Parts. It took less than 30 minutes to install.
I had the LMC5 installed in December 2013. Have a new yellow top battery. Tonight I have the "Service Steering Column Lock Soon" message. What's up? How do I proceed?
C5 Column lock systems definitely are mysterious little devils, install 2 LMC5's,
on the same day, the 1st into my '02Z and the 2nd into my son's '02Z. No problems with the 1st one, No service Column Lock or Pull key ...., everything works as it should,
however on the 2nd install, it worked ok the 1st day then got the Pull key message on
the 2nd day, which happened to be on a Sunday. I called Richard at Compliance and
left a voice message hoping he would call on the next business day, I was wrong, I received a call back less than a hr. later and to Canada no less! He said that it's more than likely a BCM to LMC5 timing issue and that the 5 wire LMC5 will be sent out to me ASAP, now that's customer service for you!
Got the 5 wire version LMC5 the other day and happy to say no more CL problems!
had the recall done - not done properly and dealer went out of business. column locked and took to new dealer who honored the recall and installed a new harness and upgraded firmware. happened again and now being told $500 for a new steering column actuator that is sticking and not part of original recall. care is a 2001 c5 6-speed.
Took the advise I received here. Emailed vendor. They gave me some suggested repairs. First was to remove neg cable for 60 sec. I did that, AND wiped key with alcohol. First solution took care of the problem. I wish ALL vendors stood behind a product like these people. Can't rate them high enough!!
Love my C5!! And this forum. Thanks to all for suggestions and solutions.
Just got my first column lock message. SERVICE COLUMN LOCK. Steering wheel locked and fuel cut. PULL KEY 10 SECONDS. I had already been reading up on the forum regarding this problem since my car seems to get every C5 infection known to man (bad valve springs, leaky butt, rocking seat, black clutch fluid, etc)... of course this would eventually happen. So, I pulled the key, turned the wheel full clockwise, re-inserted the key and gave a hard CW jerk. Started right up. I got home, called Richard at Complianceparts, he quickly responded, offering an Active Duty military discount to me, gave me the rundown for various shipping options since I'm overseas. It was beyond excellent customer service and the item is on its way the same day. He finished up by sending me a link to a youtube video for installation and provided several procedural quick fix options for the interim. Thank you Richard and Compliance Parts!
Looking for some help.Had the typical steering column lock and 2mph fuel shut off.I am in a bi t of a remote location.Talked to richard at compliance parts and ordered the lmc5 kit but have to wait for it.In the mean time my wheel was not fully locked. You could turn it but it made a chining sound as though the locking pin was just touching.Richard told me how to jump the scl relay and I did get it to fully unlock. No more chinging sound.However I still have the scl message and 2mph fuel shut off problem,obviously this relay is bad and richard says it wont be reqired once i install the kit.My question is this.How can i get rid of the scl message and fuel shut off so I can move the car to a safer location while i am waiting for the kit.Would replacing the faulty relay be a temporary fix.Thanks in advance.Greg.
Got the pull key 10 secs and service steering column problem a few days ago. 2002 Z06 with the column locked. Ordered, received and started installing the LMC5 with a unlocker, but the column motor never ran when I went to run it to the unlock position. Now I suspect the motor is bad. Can I remove the lock plate myself, or will it require some special tools?
Contact the guys u got lmc5 from, they r good n fixing your problem, i got one ordered and my cl is working fine, but who knows when it will lock.
Started pulling the dash/steering column/center console apart to get to the lock. Removed the turn signal stock and the wiper control stock and was contemplating having to remove the steering wheel. Decided to give the unlocker one more try while I tapped on the lock/motor assembly with a hammer and the motor ran to unlock the column! Now I'm back to putting the dash back together and finish up the LMC5 install.
Finally had the dreaded Column Lock issue! Had to write it up. MAJOR props to Compliance Parts for a very good kit and fantastic tech support.
2000 M6 car. PO owned since 2003-ish and never had an issue.
I backed the car out of the garage to wash & wax for a Cars & Coffee, and the “Remove key” message popped up. Some seconds later, the column locked and “Service column” message appeared. Rats! Well at least it happened at the house, and my wheels were even still pointed into the garage. My guardian angel was on the job on that one!
I tried the usual tricks: disconnecting the battery, shaking the wheel, etc. No go. Inspected the entire electrical system very carefully. Mostly a desert car, so little to no corrosion on the electrical system. Cleaned everything real well anyway, but made no difference.
Read this thread and ordered the kit and the Unlocker from Compliance. It came in a few days later. Very exhaustively written, concise instructions with pictures.
The major hitch was that I could not get the Unlocker to work. I fought it for a good 30 minutes – double and triple-checking the setup, etc. The column lock would not disengage. I finally called Compliance and he picked right up! Wow! He very smoothly verified the correct use of the Unlocker, then said I’d have to pop apart the clamshell plastic on the steering column & wack the column lock motor physically to knock it loose (similar to wacking on a jammed starter). With Richard still on the phone, I rocked the steering wheel ‘One More Time’, tried the unlocker, and shazaam! It worked.
The rest of the installation went smoothly and the car is happy now.
Long story short: Compliance makes a nice product, and excellent tech support. Highly recommended.
Note the kit disconnects the column lock completely, so it can never lock up the column. The plug for the relay is left empty by the BCM, and the relay itself can go in your box of spare parts.
Just got finished with the LMC5 install today and had to use the unlocker as well. Glad I had both on hand as the column locked this morning and would not unlock. Glad it was in my garage. All I can say is don't wait to order and install the LMC5. It's like the headlight gears. Sooner or later it's going to happen to your car. Also, I couldn't be happier with Richard and Compliance Parts. I must have called him 6 times today. I didn't think I was going to get the column unlocked but Richard kept encouraging me and giving me different things to try. It finally worked and I took it for a ride to make sure there were no issues. Everything worked out great thanks to Richard's excellent customer service. Now if I can just get around to doing those headlights....
Remember to let the dic do it's thing maybe 2 seconds before u crank it or u may get the pull key 10 second message, i did it to quick and got the message, richard told me to pause before cranking. It works
I have a 2000 corvette stick shift. My steering wheel locked up and spoke with dealer and he said I can tow to dealer OR try to disconnect battery and touch the cables together and hook back up and see if the computer resets...any ideas ?
Order the lmc5 device, have it overnight shipped, 40.00 plus shipping. I installed it on mine lsat week. Pretty easy to install. Search for the youtube on it.
Thank you so much I will find someone to install for me. I'm new to this and appreciate the feedback.
