Old Feb 20, 2015, 12:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
Steering Column Lock FAQs - please read before you post (sticky please)
Old May 6, 2015 | 06:07 PM
  #1801
LateBreak's Avatar
LateBreak
My original relay looks 100% perfect inside, and I get a Service Column Lock message with the brand new one installed. Seeing as how GM couldn't get this system to work right anyway, I'm putting my money on the homebrew CLB and a jumper wire in place of the relay. What a stupid system...
Old May 6, 2015 | 10:00 PM
  #1802
DougG's Avatar
DougG
Default GM is dodging a bullet
My 2001 coupe, owned since new, was serviced under the column lock recall in 2004. Now it's stuck with a locked column in the garage. Any point in calling GM? If so what's the number?
Old May 21, 2015 | 12:39 PM
  #1803
BigBill303's Avatar
BigBill303
6th Gear
I am the original owner of an '04 Vert / 6 spd manual.
Battery died over the winter. Jump started it with another vehicle. Had 2 warnings on the DIC - Service Active Handling and Service Column Lock - otherwise it was fine. Drove it up the street, turned around and parked it in the driveway.
Knew the battery was toast so I went and bought a replacement at the local auto parts store. After installing it that's when the fuel shut off began to occur. After research I returned the battery and bought the recommended battery from the dealership.
After I installed the 2nd battery I got the "Pull Key, Wait ..." message. (I hadn't received this DIC request before this).
Did, but still have the Service Column Lock message and still the fuel system is shutting off ...
My column works fine. When the key is removed the column locks. When the key is inserted the column unlocks.
Everything appears to be 'normal' except that the fuel system shuts off as soon as it moves forward or backward ...
Old May 21, 2015 | 02:00 PM
  #1804
LateBreak's Avatar
LateBreak
Mine was working fine too, the problem is that the BCM isn't seeing the feedback it needs in order to be sure that it's working. So, it's killing the fuel to prevent you from driving with a locked steering wheel. Time for a bypass
Old May 21, 2015 | 02:33 PM
  #1805
BigBill303's Avatar
BigBill303
6th Gear
Is that the LMC5 Module from Compliance Parts?
Old May 21, 2015 | 02:34 PM
  #1806
LateBreak's Avatar
LateBreak
I built my own, but the LMC5 is a great solution for a good price.
Old May 21, 2015 | 02:57 PM
  #1807
BigBill303's Avatar
BigBill303
6th Gear
Built your own? ... Talk to me MacGyver ........
Old Jun 6, 2015 | 05:59 AM
  #1808
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I have a CLB for sale if anyone is interested, parting out the car so PM me if interested...
Old Jun 14, 2015 | 09:23 AM
  #1809
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Mine locked after 13 years of ownership and no recalls done. I chose the LMC5 over a recall because I don't want the dealership messing with the car with all the mods it has. It installed easily, but the column unlocker did not work. Compliance Parts responded very quickly to an email. They told me to call them and they'd walk me through unjamming the lock motor. I'm trying to find time to work on it again. Hopefully tomorrow.
Old Jun 22, 2015 | 02:11 PM
  #1810
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
Bless you guys..... I've ordered my part. Priority shipping.... UGH... LOL
Old Jun 24, 2015 | 01:49 AM
  #1811
spazzman90's Avatar
spazzman90
6th Gear
Just thought I'd add my experience today here....
2002 6MT 57K miles.
Recall for disabling the steering lock done 2004. Recall for adding the K-Harness done 2008.
Been driving fine last 3 weeks. Running errands today no problems. Got to work and had to move my car after sitting for about 15 minutes. remove key. ok. Service column lock. Then it just says Service column lock. Seems to take like 15 mins and it resets. Says remove key first and then Service column lock only. Of course fuel cutoff at 2 mph. Not driveable. Ugh.... Why now?
Ok. So tried a different key. No go. Tried putting a 10 amp battery charger on. No go. Tried disconnecting the battery for 20 mins. No go. Disconnected the battery for 30 mins. No go. Got under the steering wheel (4 screws) and took the K Harness out of the loop and restored original connection. Fixed the problem. At least well enough to get me home. Yes, I will get an LMC5, but maybe if you're in a jam and reading this stranded in a parking lot like I damn near almost was, mabey you happen to have a small torx bit so you can remove the knee panel under the steering wheel and get rid of the damn k harness and get on your way! Good luck...
-Jeff
Old Jun 24, 2015 | 11:05 AM
  #1812
GM350Z's Avatar
GM350Z
UGH, had my Z for 4 days and the column lock message appeared. Scanned the BCM, stored code for a key pellet. I read sometime it can happen with low battery voltage and i have a super ****** walmart battery so im gunna try and interstate or optimo and a new key first probably before i go cutting into my BCM harness. Good news is if i go ape **** on the column than put the key back in, itll unlock itself.
UPDATE: Called at the dealership to ask about the recall. They told me its already been done on my vehicle. Changed the walmart battery to an interstate MT-75, car unlocked itself on the next key cycle and has been fine ever since.
Old Jun 27, 2015 | 02:22 PM
  #1813
Mike Beck's Avatar
Mike Beck
SO, I installed the LCM5 yesterday, not realizing I needed to unlock the steering wheel first. Out of the three wires removed, green, purple, and orange, what did these do? Can I simply apply power to the correct wire to run the steering wheel lock motor in the correct direction to unlock it for good? I can't find anything regarding the wiring.
Or, do I have to put it all back to original, turn the key on, make sure it unlocks, then disconnect the battery while the wheel is unlocked, and re-install the LCM5? Right now car is stuck in the driveway with no way to move it.
Old Jun 28, 2015 | 05:49 PM
  #1814
spazzman90's Avatar
spazzman90
6th Gear
Hey Mike,
Let me know how it goes with this. I am about to install a couple and this exact question was on my mind. I was figuring the install instructions would address this. I was thinking I would just turn on the key and disconnect the motor at that time and then proceed with the LMC5 installation as normal. Please share what they recommend as to how to proceed. Thank you.
-Jeff
Old Jun 29, 2015 | 05:09 PM
  #1815
Mike Beck's Avatar
Mike Beck
Originally Posted by spazzman90
Hey Mike,
-Jeff
I did not understand his website, but it was perfectly clear on there. My fault. If you're wheel locks, then you need (or I should say highly recommend his unlock kit). For the money, you cant beat it.
You will start the LMC5 installation, and towards the end, before you reinstall the BCM into position, you will use the unlock kit. Very simple, took me a few minutes and I was done!
If your wheel does not lock, then you don't need the unlock kit. All his unlock kit does is run the motor in the correct direction to unlock the wheel, that's it. Once unlocked, it can never lock again. That is because the BCM no longer has control over that motor due to the installation of the LMC5.
All in all, about 1/2 hour installation project, unless you're in better shape than me!
I gotta say, he is FAST! I ordered the unlock kit on Saturday and had it today on Monday, that is amazing! Now my wife can drive her car, she'll be VERY HAPPY!
Old Jul 3, 2015 | 10:16 PM
  #1816
ArtGle's Avatar
ArtGle
I bought the bypass from Corvette Central first (silly me) because I didn't see the LMC5 part of this. Anyways, it didn't work. Called Corvette Central and they referred me to some place in Houston, TX. Called them and spoke with their tech. "Refund". Sent it back. Bought the LMC5 and it installed slick as butter.
Problem solved. Waiting for refund from Corvette Central.
Old Jul 5, 2015 | 04:05 PM
  #1817
BigBill303's Avatar
BigBill303
6th Gear
Default Steering Column Lock
So I researched and found many threads referencing the issue I was having with my Service Steering Column Lock message (as mentioned above) ..
After receiving some tech advice from Paul we began to narrow it down to the Steering Column Lock Actuator Motor.
I had that replaced and all is good now.
What I've learned is that solutions can vary, whether it be the lock motor, harness, bypass, relay or just the battery replacement .... it all starts with the battery voltage ..
Keep your battery fresh and this shouldn't happen ..... lesson learned.
To Steering Column Lock FAQs - please read before you post (sticky please)
Old Jul 5, 2015 | 04:11 PM
  #1818
37pat's Avatar
37pat
Default LMC5 variations
I installed an LMC5 on my 03Z recently. I also replaced my 9 year old battery. I've never had a service column lock or "pull key . . ." issue, but installed the LMC5 as a preventative measure.
I am now getting 30%-50% "pull key . . ." messages. I plan to do the brown wire mod this afternoon. Is the brown wire mod an alternate to the 5 wire LMC5, or is that the "final solution"?
Pat
Old Jul 18, 2015 | 03:28 PM
  #1819
HFDSRCAPT78's Avatar
HFDSRCAPT78
Cruising
So I have just bought a 2000 coupe with 2900 miles on it, a week later the service column lock showed up, ordered LMC5 and got a new Battery, Charged Battery to 100% and problem resolved, will keep trickle charger on Battery and should I install LMC5 to be on the safe side?
Old Jul 18, 2015 | 06:48 PM
  #1820
marks146's Avatar
marks146
Default LMC5 in, and leave it in.
Absolutely!!!
With it installed you will NEVER have the problem show up. You don't want to be in the shady part of town getting gas in the wee hours and not be able to start your car.
Keeping the car on a Battery Tender type trickle charger is a good thing to do unless yours is a daily driver. If you do a search you will also find a list of suggested batteries for your car. Not every battery is the same. I have an AGM battery so there is less chance of acid leaking onto the precious wires under the battery tray. This is another issue to be wary of.
Get that LMC5 installed, and leave it there.
