C5 headlight flutter
Old Feb 15, 2005 | 06:56 AM
RGAREY's Avatar
RGAREY
3rd Gear
Default C5 headlight flutter
Just purchased 98 coupe and noticed on the drive back the drivers headlight flutters. i can see it is loose on the link from the drive motor to the housing, my question is there a bushing or is the link worn and need replaced?
Old Feb 15, 2005 | 10:27 AM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
My '02 Z06 does the same thing. I couldn't see any way to fix it short of taking it apart and replacing or machining a new "link" bar.
Old Feb 15, 2005 | 11:23 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Mine did this and upon inspection I found that the up/down adjuster had popped off. Mine was pointed way up while it was like this though.
HTH
Old Feb 15, 2005 | 10:49 PM
tunnie's Avatar
tunnie
Cruising
My 2000 does the same thing...driver's side. I'm going to take it apart this weekend...will let you know what happens
To C5 headlight flutter
