Intermitten Windshield Wiper Problem
Old Feb 15, 2005 | 12:31 PM
slammedwhitec5vert's Avatar
slammedwhitec5vert
Default Intermitten Windshield Wiper Problem
My Wipers Don't Always Work Is There A Common Problem To Check First.
Old Feb 15, 2005 | 04:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ohhhhhhhhhhhhh Yeaaaaaaaaaaaaaaaaaa! There is a common C5 issue that can cause this problem. There are three windshield cowl drains on the drivers side. They look like this:
If the drains clog up, they can cause your wipers to have issues. Sometimes they will come on all by them selves and sometimes they will not work at all.
You can access the drains by sticking your hand in this area:
If the drains are HARD they will be packed with trash and GOOK like this:
Please let me know if this fixes your problem and if you have any more questions.
Bill Curlee
Old Feb 15, 2005 | 07:46 PM
6 speed Sid's Avatar
6 speed Sid
I had to replace the stalk.
Old Feb 15, 2005 | 09:36 PM
slammedwhitec5vert
Thanks for the info guys it'll give me a place to start.
Old Feb 15, 2005 | 10:34 PM
tunnie's Avatar
tunnie
Cruising
I agree with Bill. Almost sure your problem is clogged drains. When clogged, water will submerge the control module mounted under the wiper motor and short out the system. Replacement module from Dealer = $100.00....everyone should make sure this drain is clear
To Intermitten Windshield Wiper Problem
