Best shorty headers??
Old Feb 16, 2005 | 10:41 AM
vetteamerica's Avatar
vetteamerica
Default Best shorty headers??
I want to install shorty headers on my 97 mn6, I know LT's are better but I prefer shorties at this time. I read some threads and got mixed reviews. I would like 1 3/4" tubes and coated. I am also concerned with ease of install and any problems with changing plugs afterwards and of coarse price.
Here's a list of the ones I came up with, if anyone has info please chime in:
BBK
JBA
Borla
etc..........
thanks....
Old Feb 16, 2005 | 10:54 AM
IM QUIKR's Avatar
IM QUIKR
B&B are stainless steel and have 1 3/4" primaries. 10-15hp gains from what I've seen and the dyno shows the bigger gains from 3000-5500 rpm range. But you'll get most folks here pushing you to the LT headers. Personally the 1100-1800 price tag is not worth the gains. I picked up my B&Bs for $150 used. I may just get them coated before the install. Here's a link to the install process.
B&B mag review and install overview
Old Feb 16, 2005 | 10:58 AM
FKING1's Avatar
FKING1
Put B&B Tri flo shorties on my MN6 00 Coupe 5 years ago. Install not too difficult, just take your time. Had them ceramic coated also. Only prob was the dipstick attach hole was a mile off and had to bend and rework to line up.
Fred K.
Old Feb 16, 2005 | 11:04 AM
RAFTRACER's Avatar
RAFTRACER
Waste of time and money, you'd probably be better off using someones '02 later Z06 manifolds. you can probably buy these for next to nothing since we all use long tubes. You would also need the center section to match. ST's are a complete waste IMO
Old Feb 16, 2005 | 11:30 AM
ragtopws6's Avatar
ragtopws6
They are not worth time/money IMHO.
Old Feb 16, 2005 | 11:33 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Want my '02 Z06 manifolds? Make me an offer...
Old Feb 16, 2005 | 11:42 AM
vetteamerica
I thought of using newer ZO6 manifolds (seen them on ebay) but I don't think the smog connections match up to my 97. If anyone has done this please chime in.
I have to disagree that shorties are a waste of time & money because I have to believe that they will flow much better than the stock 97 manifolds will.
Any known problems with spark plug changes??
Old Feb 16, 2005 | 11:43 AM
vetteamerica
Do you know if the smog crap will match up to my 97??
Old Feb 16, 2005 | 12:42 PM
Mitch C's Avatar
Mitch C
Old Feb 16, 2005 | 12:45 PM
dmtnt's Avatar
dmtnt
Not sure if they'll match up, but my '02 manifolds have an AIR inlet on both sides.
Old Feb 16, 2005 | 01:17 PM
RAFTRACER's Avatar
RAFTRACER
No they will not, but it is a very minor fabrication job, the air pump tubes are still there they are just located more forward than your '97. I believe if you do this though you will need the later-model center section .
Old Feb 16, 2005 | 01:24 PM
vetteamerica
I read some threads after searching and found it will be more involved than I thought.
I think I am going with a good pair of shorty's at this point.
thanks for the info!!
Old Feb 16, 2005 | 01:48 PM
leaftye's Avatar
leaftye
Just take off the AIR and disable the SES code. Easy...and free if you know someone that has a HpTuners for a '97. I think SLP sells the AIR blockoff plate for around $10.
Old Feb 16, 2005 | 01:55 PM
vetteamerica
But I also read that the H pipe will not match up (different angle) and I just had a complete SS exhaust done by Mufflex from the manifolds back.
Old Feb 16, 2005 | 01:57 PM
lost's Avatar
lost
BBk has ceramic coated shorties for our cars and I know of a dealer selling them for less than $500. One of the ls1tech guys donated his car for the guinny pig and he got excellent results at the track, I may put on my car just for the pretty factor ...lol
Old Feb 16, 2005 | 02:01 PM
vetteamerica
But I heard BBK's are junk?
Anyway who is the dealer you found?
Old Feb 16, 2005 | 02:14 PM
lost's Avatar
lost
PM sent, 5.0 mag tested them and their shorties were almost as good as thier longtubes on the dyno.Only complaint I've heard about was a lip left in the collector easliy fixed with a dremel
To Best shorty headers??
Old Feb 16, 2005 | 03:46 PM
Mr. C's 5's Avatar
Mr. C's 5
First off 97 – 99 shorties are unique, as are 00’s and 01 – 04’s. They are longer with a different bolting pattern. The air tube on the passenger side is toward the firewall, same as an 00. The air tube on the drive’s side is the same on all. B&B’ are all stainless and will flow much better than the stock manifold. BBK and JBA are coated mild steel and of a different design. SLP’s are stainless but not bolt on. Borla doesn’t make headers for 97 – 99. 01 and up stock headers are of a better design than yours but the air tube and down pipes wont match. The ports are also of a different shape. While I mostly do agree with the LT bigots (mostly), if your car does not have head and cam work, you really won’t get the most out of them. Well designed short tubes do add some HP, especially over stock 97 – 99 manifolds. It’s up to you to decide if it’s worth it. - C.
Old Feb 16, 2005 | 04:25 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Except I paid 375.00 for mine! They were mint / like new however, so that's cool.
Old Feb 16, 2005 | 06:44 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
The best set of shorty headers are already on your car.
