'Hot' vs. cold air intake?
Bob
Korreck, please give more of your wise advice and opinions. I really like that fact you think there is no such thing as cold air.
Does the word "dense" mean anything to you. I know your slow, so I'll spell it out for you... I'm talking about your head.
http://www.vetteguru.com/ramair/
http://www.vararam.com/reality_of_ram_air01.html
And regarding real ram air, I think some of you are confusing positive boost with ram air. As we all know, real-world positive manifold pressures can only be achieved with Forced Induction, such as blowers and turbos. A good ram air system will alleviate pressure loss in the manifold, but will not create positive boost. By alleviating pressure loss, you are feeding the engine more air, or perhaps allowing the engine access to air that is accelerated into the intake manifold that otherwise would have to be "sucked" into the manifold. A good induction system will accelerate the air into an engine, making more air available "on demand". Ram Air technology has been used in the superbike field for years. Kawasaki has been especially successful in engineering good ram air systems for their bikes. Why spend millions on the design and propagate it in product after product if it doesn't work?
http://sportrider.com/tech/146_9910_ram/
http://sportrider.com/tech/146_9912_ram/
Maybe we just shouldn't call it ram air. Perhaps we should call these gadgets airflow accelerators? You true skeptics will fully investigate BOTH sides of the equation, right?
There was no significant difference in temperature between ambient and intake at speeds over 5mph.
The pressure difference caused by the filter media is similar for all aftermarket oiled filters.
I created a true Ram Air through the license Plate opening. At 100 mph the increase in pressure at the license plate is about 6 inched of water, 0.25 psi. About 1.8% more HP, The pressure increase at 60mph was not significant.
I have been told that at high speed the running light openings will actually go into negative pressure, however I didn’t test that theory.
My results find no support for the cold air claim as both filters see the same air temperature. Vararam being more expensive and harder to install can only be a psychological benefit. Vararam offers no empirical data to support their performance gains. These tests cost less than $25 out of pocket to perform.
But then again I could be wrong
1/4 mile: 13.91 @ 106.8 MPH vararam
1/4 mile: 14.13 @ 105.1 MPH blackwing with modifications to allow in cold air
Seems like a reasonable claim to me, .22 seconds and 1.7 mph. I wil eat my K&N filter if it can not beat a blackwing by that much.
Quote:
Originally Posted by Korreck
Ok, then go to DTE and Lingenfelter and see what they put on their packages. No such thing as ram air or cold air unless you run it through a refrigerator.
Bob
Just because 2 tuners may not advertise them as part of their "package" means what???????????????? Why does Lingenfelter use intercoolers on his turbo cars???????????????????????????????????? ????????????????????????????????
Thanks for the
I needed that today.Come on Korreck, why won't you tell us what an intercooler does????????
PLAYED AGAIN!!!!!
What materials and methods did you use to measure the temperature and pressure around the Blackwing.
Ignorance is bliss, and facts are indisputable. Have a good day.
During the afternoon when the ambient temps reached 85+, the intake air temps climbed up to a max of 150F at 30 mph and then cooled off to 129F at 80 mph.
My point? At these intake air temps, the engine CPU is retarding timing enough (to prevent knocking) so that HP is down by up to 10. This is real, seat of the pants HP that is being taken away because the air filter is sucking up hot air. The Stock box, Blackwing and Halltech filters cannot pull in ambient air unless it is directed toward them from the outside, either through the front or from underneath.
Originally Posted by auctiondepot
I measured the air temperature and pressure around the Black Wing.
Hmmm...auctiondepot, where exactly did you measure, what did you use to measure and what exactly were your numbers?
Ed
If you read Korrecks posts, you will see that he makes absolutely zero sense and does a good job of letting everyone know just how ignorant he is. I think it's very funny. I hope he comes back to play today, assuming he's allowed on the computer today. I'm sure his parents are going to tighten the lease when they see all of his late night computer activity.
The guy said there was no such thing as cold air.
That has to tell you something...... he's
) you can sort by replies. This one had 850 replies and 7846 views but it was a give away!
http://forums.corvetteforum.com/showthread.php?t=914588
Less than two-tenths psi at 100 mph doesn't sound like much to me, my Vortech needs to reach about 1.5 psi before the boost is noticeable, but what the hay, that's me and you may feel even the thrust of .09 psi at 70 mph... =;-
True, it's not much, but it's more than the Blackwing gives, and thats what the thread is about.
The Vararam's foam filter is 'porous' compared to its K&N replacement, or the Halltech Warhead filter, Blackwing, etc.
Performance-wise, I wonder how a 'stock' Vararam compares to a 'modded' Vararam with a K&N filter replacement?
'High flow' filters allow more air to flow through them, but with the added risk of more debris flowing into the engine, too.
Always a trade-off somewhere.....
Just food for thought.....
Ed
This thread serves one good purpose... Lots a bone crushing laughter.
