'Hot' vs. cold air intake?
Old Feb 18, 2005 | 11:18 AM
RacrX's Avatar
RacrX
St. Jude Donor '08
Default 'Hot' vs. cold air intake?
If you replace a Blackwing with a Vararam, do you think there would be a noticablr difference? Worth the money?
Old Feb 18, 2005 | 11:30 AM
adrnln1's Avatar
adrnln1
You will get LOTS of opinions here... I made the change late last year and I really notice a difference on cooler days, not so much on warm ones (which kind of makes sense).
Depending on how you like to drive is whether you'd notice anything or not... on a cool morning the difference is huge (my $.02).
Old Feb 18, 2005 | 11:33 AM
4BTINGU's Avatar
4BTINGU
Don't know about the Blackwing. However, I replaced a duel cone 'Cold pro' intake with a vararam. BIG change. Vararam just keeps pulling! The faster you go, the more air it sucks! I LOVE mine. Well worth the money for me!
Old Feb 18, 2005 | 11:38 AM
rudolph schenker's Avatar
rudolph schenker
I think the Vararam is the only true CAI. MIne works very well!
Old Feb 18, 2005 | 01:38 PM
carnut108's Avatar
carnut108
Forced induction just makes sense.
Old Feb 18, 2005 | 01:46 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
I used a product called the "Icebox" to convert my Blackwing to a CAI... my SOP meter went up on cool days....
Old Feb 18, 2005 | 01:52 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
yeah a supercharger - not a cold air intake.....
The blackwing draws cool air as well when moving, as you know it sits IN FRONT of the radiator and draws air ahead of the engine compartment.
Save your money and buy Long Tube Headers if you want a gain
Old Feb 18, 2005 | 01:56 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
"HOT" intake?
Old Feb 18, 2005 | 02:07 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Originally Posted by devo
"HOT" intake?
as in, one that draws warmedr air from the engine compartment, instead of coller air from directly outside.
MikeV's Avatar
MikeV
Big differance! I went from a blackwing to the Vararam at the end of last years race season. I picked up 3 tenths and 2 MPH in the 1/4.
The improvement was noticed and verified by a least 5 other racers in the West Coast Corvette Challenge. Well work $340.
Mike V
Old Feb 18, 2005 | 02:13 PM
devo's Avatar
devo
Thanx man but I was just messin with ya Im bored here at work
Hey where ya at in Venice I live on Ozone
Old Feb 18, 2005 | 02:21 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Oh, you so faw-nee!
Pacific & Windward
Old Feb 18, 2005 | 03:20 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The difference in HP is calculated at 1.3 % per 10 degree's of actual mix temperture..same formula is used for corrected dyno numbers.
meaning if you have a black wing that is pulling air from the engine bay at say 100 degrees,on a 60 degree day and you have a vararam pulling air from outside the car at say 60F degrees. the same car will see gains in the 15/20 hp gain, depending on individual engine, and mods. Enough to feel the difference.
Now if you have a heat extracting hood and cold air screens. on that same sixty degree day your engine bay will be 60/65 degrees. So having a black wing with cold air screens and a heat extracting hood would be comparable..
Post has been modified to correct inaccurate calculations. Thanks again
C5Xtasy
Old Feb 18, 2005 | 03:27 PM
fotoboy's Avatar
fotoboy
Just put a balckwing air lid on my 98, havent had a chance to run yet. Its suposed to be worth around 30 deg. @ speed. was recomended to build a reinforced plate tha I did to keep it from pulsing.
Old Feb 18, 2005 | 03:31 PM
Dave68's Avatar
Dave68
Originally Posted by Evil-Twin
the difference in HP is calculated at 1.3 hp per 10 degree's of actual mix temperture..same formula is used for corrected dyno numbers.
meaning if you have a black wing that is pulling air from the engine bay at say 100 degrees,on a 60 degree day and you have a vararam pulling air from outside the car at say 60F degrees. the same car will see about 5.2 hp gain. Enough to feel.
...or my cold air mod for Halltech Stingers AND Blackwings:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Total cost after you buy all the components: $40 or less.
Old Feb 18, 2005 | 04:26 PM
C5XTASY's Avatar
C5XTASY
I always thought it was about a 1% (or 1.3%, not sure) change per 10 degrees of air temperature change. It would be difficult to specify a single constant horsepower delta number, of say 1.3hp per 10 degree inlet air temperature change, for different sizes and power motors. So, by my calc, if correct, a 300 horsepower motor, for example, would gain about 12 horsepower (or 15.6 hp if 1.3% is the actual percentage change) with a 40 degree drop in inlet temperature. Not sure, but that's the way I always figured it was.
Ed
Old Feb 18, 2005 | 04:39 PM
Evil-Twin's Avatar
Evil-Twin
Ed
You are correct, and I am wrong.... Thank you for correcting this error. I will correct my original post, thanks again...
To 'Hot' vs. cold air intake?
Old Feb 18, 2005 | 04:50 PM
C5XTASY's Avatar
C5XTASY
Ed
Old Feb 18, 2005 | 06:01 PM
EHS's Avatar
EHS
Here's what TheWrench posted in another thread just recently (still active):
Originally Posted by thewrench
...I have the Blackwing. I hook up my little scanner sometimes and check the air temp coming into the engine. When I am moving at all, even around town, I see about 2-5 degrees above the ambient air temp.
I can drive all over, and never see warmer, until I stop.
When I stop and idle, or kill the engine to run in a store or something, the intake temp goes up 30, even 40 degrees.
Then when I move again, it comes down....
This isn't a SOTP observation or any placebo effect from just having spent bucks on a Vararam. Fact, --- with a Blackwing, the air temperature coming into the engine is 2-5 degrees warmer than the outside ambient air.
Using C5Xtasy's formula above, that means that the Blackwing loses about 1 horsepower to the Vararam. Big deal, and it's a cleaner simpler installation in a more water protected location.
And thanks to Ragtop_Rob above (it seems only pilots really understand "forced air induction" and "ram effect" -- because at our speeds and altitudes we live it more than the civilians do), there is no "forced induction effect" or "ram effect" with a Vararam -- unless the supercharger is mounted behind it.
There you have it -- 1hp difference -- you'll never feel it. So, what accounts for those magical 0.3 sec. increase and 2 mph differences after the Vararam install?
It's something called the "placebo effect," well known and well documented with sports equipment all over the world. Nike has made billions as a result.
Cheers!
Old Feb 18, 2005 | 06:24 PM
Evil-Twin's Avatar
Evil-Twin
Engine bay temperatures right now when it's 20 degrees outside are going to be cold.. but on a hot summer day when the engine is sitting on top of a 160 F blacktop road and the engine bay is seeing temps in excess of 130 F, 90 degree air is cold...
