'Hot' vs. cold air intake?
1) The physics behind introducing cooler, therefore denser, air into an engine...more oxygen, and not rolling back timing - two benefits
2) Drive your car when it's cold outside and note how it performs vs when it's hot outside. There is a significant difference. That is all due to inlet air temperature.
The Vararam is a sound design. That's why I bought one. The Blackwing is a good design, also. The compromise is it draws underhood air. Using a cold air shroud on a Blackwing will also work except you add the hydolock concern because it draws air from the front dam area. The Vararam draws air from the foglight area. No scooping action like at the front dam area.
Ed
Actually, the foglight area is at about the same height as the scoop in a radiator shroud cutout system (or at least fairly close to the same height.) I noticed this when I was installing my cold air scoop. Therefore, the chances of hydrolock are fairly equal. That being said, I must mention that I have driven my car in heavy downpours and the worst that happens is the bottom of the filter gets a bit moist.
The nice thing about the radiator shroud cutout design is that if you have headers, you can both cool the intake air and cool the engine bay by cutting up or removing the fog light covers. This is something you cannot do after installing a Vararam unless you install offset scoops onto the lower radiator cover. Having less than hot air in your engine bay is important if plastic and rubber component life is important. The old Mercur turbos would cook belts and hoses very quickly, due to the high underhood temps.
Ed
Besides, the old "bottom feeders" were traditionally intake filters that extended below the radiator cover and into the airstream. The latest cold air systems position the filter inside the engine bay, well out of harm's way.
The only gains you may see would be from the temperature difference of where the air is drawn in, and even then I'd bet my next paycheck that the difference between the vararam and blackwing is negligible as far as real world HP is concerned...
Here's the new Jim Hall, right off his web site:
"The Stinger Intake is our newest intake system, and is probably the baddest *** intake on the market for the money. It features the same 25% more than stock flow numbers of our TRAP..."
And, here's a picture of the "Halltech Stinger:"
Compare that to the Blackwing:
Notice any, errr...., similarities?
Jim copied the Blackwing (which came first), right down to the filter color, after he had all the headaches with water ingestion back in the original "cold air" days with his now discontinued "TRIC." Some motors blew up and all of a sudden the "lifetime warranty" issues became very real for him. His new "cold air" intake is only recommended for "track use," and I don't know if it still comes with the same wet-suit waterproofing booty he was selling with the TRIC before that thing was completely discontinued.
Another "improvement" he touts is the "Warhead" filter -- the "highest flowing filter" and "least restrictive" on the market. You know why it flows so much? Because it also filters less.
The highest flow, least restriction comes from no filter at all.
There's a reason why the U.S. Army uses your tax dollars to put Donaldson filters on every tank, truck, and HUMVEE in the deserts of Iran and Afghanistan. They work. They "flow." And most importantly, they "filter."
That's the kind of performance and protection I want for my motor.
Finally, regarding your comment that you can't see the benefit of cold ari induction on the dyno, why not?
Isn't the "cold air" coming from the outside, and the "hot air" coming from the hood side? There should still be a difference, shouldn't be there? I think you may have confused the dyno "cold air" effect argument with the dyno "ram air effect" argument. Both benefit greatly when the SOTP meter is used. Can't be measured, but boy, it sure feels like it's faster. Known as the "placebo effect."
Cheers!
Good job. I have thought about running a tube from a cooler to the Vararam for true cold air. But I still haven't figured out how to slow the air so it really has time to cool off. We could put the supercharger industry out of business. Cold air and ram air. Just need help with the design.
Guess I'll stick with my Blackwing for now.
Now here is a fact from someone that actually had both systems on the car. I went from a Blackwing to VARARAM and gained an avg. 3mph and 4/10's. My car is/was a VERY consistent a/4 that ran 12.25's @ 113 ALL DAY LONG for over 1 year. Swap to VARARAM gave me (the only change) VERY consistent 11.81's @116 mph. These gains stayed with me for over one year, racing at different times, days, DA's blah blah blah. BTW, my consistency with both intakes was within 3/100's. Maybe the printer at the track was given a "placebo" just to pacify me for spending $300 on a VARARAM.
For all you nay-sayers that have never done it or even been to the track to test out your "theories", I suggest that you shut your mouth when comes to giving advice until you have "been there and done that".
I find it funny that the fastest N/A C5's in the country run VARARAM. But then again, what do they know, they ONLY RACE THE CARS and can choose any intake they want.
I always get a laugh out of guys like you. Please explain my gains.... I'll be waiting.
It's all about money for many...the claims increase the money because of so many blind consumers.. These vendors after offering something so shameless, leave the forum only to return months later with some other piece of crap...
Guarantee offerings are only posted until someone wants their money back...Why are so many offering from one vendor in particular always discontinued after a few months, and people are always after him for their money back or damages cause by poor design..
Quote:
You guys have no clue "what real world HP is".
Great, put up your paychecks. I'll gladly swap back to a Blackwing, get some runs and then go to Vararam and baseline again. Well........... lets see those paychecks.
Maybe your old filter was clogged. Maybe it was 40 deg cooler on that day. Go to the track, run your VaVaVAVaram and then change to the Blackwing. You won't like what you see.
Bob
On the one hand we have the VaraRam which draws it's air supply from outside and in front of the car. The theory is that it is significantly cooler air than that which the Blackwing sucks up.
Well.
The Blackwing indeed sucks up air, but is it the hot air from under the hood which one observes as the car sits, or is it new incoming air in front of the radiator shroud, introduced under the hood as the car moves?
It would seem reasonable to believe that the Blackwing gets its air supply from in front of the radiator shroud as the car moves. If this is the case then there should not be an appreciable difference in air temperature. This "new" air should not be much, if any, warmer than the air entering the vararam.
This idea that the Blackwing takes in hot under the hood air doesn't hold up because new air is taken up as the car moves along. If the engine compartment were sealed airtight, then maybe I could make sense of this theory. But it is not. Thats why the car runs. The engine compartment is not sealed, new outside air comes in. The position of the Blackwing is far enough anterior so that when the car moves it should not take up anything but cooler, outside air coming in.
From a practical standpoint, a "real world" standpoint, here is what I have seen.
1. At least 2 Z06 owners at my local track who say they have not seen any performance difference which could be attributed entirely to the Vararam.
2. Cars running the Vararam and otherwise modified very similar to my own with best ETs slower than my own. While it is difficult if not impossible to compare time slips from around the country, this is a sticking point for me in making a decision to make a switch.
3. Nothing more than anecdotal evidence from those here who claim improvement in the Vararam vs the Blackwing. Their improvement could be the result of track prep, DA, etc. This takes on new significance since the improvements the Vararam is said to give over other systems typically cannot be seen in dyno graphs.
When I add all this up with the poor fabrication, fit, finish and quality of workmanship of the Vararam, the potential for hydrolock, the poor quality of the air filter element, the difficulty of the installation, along with the questionable at best benefits it offers over the Blackwing, my choice is easy.
The VaraRam is probably snake oil. Some of the claims they make, I mean 0.3 improvement in the quarter mile is some serious power.
Bob
Like I said below, the car ran X for over a year, that means in excess of 30 runs in the course of over a year. Switched to VARARAM and ran Y for countless runs in excess of a year. NO OTHER CHANGE. Please explain the increase in trap and decrease in E.T. Once again, I'll be waiting for your "theory".
Put VARARAM on one car and a Blackwing on the other, and watch the VARARAM car walk away from the Blackwing car. Arm chair quarterbacks.
"Now here is a fact from someone that actually had both systems on the car. I went from a Blackwing to VARARAM and gained an avg. 3mph and 4/10's. My car is/was a VERY consistent a/4 that ran 12.25's @ 113 ALL DAY LONG for over 1 year. Swap to VARARAM gave me (the only change) VERY consistent 11.81's @116 mph. These gains stayed with me for over one year, racing at different times, days, DA's blah blah blah. BTW, my consistency with both intakes was within 3/100's. Maybe the printer at the track was given a "placebo" just to pacify me for spending $300 on a VARARAM."
Have fun with your Blackwings, in second place of course.
During the afternoon when the ambient temps reached 85+, the intake air temps climbed up to a max of 150F at 30 mph and then cooled off to 129F at 80 mph.
My point? At these intake air temps, the engine CPU is retarding timing enough (to prevent knocking) so that HP is down by up to 10. This is real, seat of the pants HP that is being taken away because the air filter is sucking up hot air. The Stock box, Blackwing and Halltech filters cannot pull in ambient air unless it is directed toward them from the outside, either through the front or from underneath.
