'Hot' vs. cold air intake?
When the car is moving, the engine bay temperatures in front of the radiator and not within millimeters of the exhaust will be the same as the outside air. Please rfer back to TheWrench's post.
Thank you.
Difference in intake air from a Blackwing and the ambient air is > 5 degrees Fahrenheit, or about 1 hp.
So sorry. Placebo effect.
pla·ce·bo ( P ) Pronunciation Key (pl-sb)
n. pl. pla·ce·bos or pla·ce·boes
1. A substance containing no medication and prescribed or given to reinforce a patient's expectation to get well.
2. An inactive substance or preparation used as a control in an experiment or test to determine the effectiveness of a medicinal drug.
3. Something of no intrinsic remedial value that is used to appease or reassure another.
4. (plä-chb) Roman Catholic Church. The service or office of vespers for the dead.
Difference in intake air from a Blackwing and the ambient air is > 5 degrees Fahrenheit, .....
I thought that the difference in intake air from a Blackwing and the ambient air was < 5 degrees Fahrenheit.
"The Blackwing sucks hot air. At 95-degrees IAT, the Blackwing will lose 1 degree of timing. At 135-degrees a full 12 degrees is pulled on the LS1 which equals 10 RWHP."
Before installing my cold air mod, in which fresh outside air is directed at the air filter from underneath, I would drive home on a Summer day and after criusing at a steady 50 MPH for 3 miles, would pull into my garage, pop the hood, and place my hand on the plastic airbridge. It was VERY hot to the touch, so much so, that I had to pull my hand away.
Repeating this procedure AFTER my cold air mod and on a temperature-similar day, the airbridge felt cool to the touch - a SIGNIFICANT difference, obviously due to the cold air scoop.
Folks, cold air induction works, and works well. You often cannot see the benefits on the dyno, but believe me, the SOTP difference is there.
The difference is less than 5 degrees Fahrenheit.
...Folks, cold air induction works, and works well. You often cannot see the benefits on the dyno, but believe me, the SOTP difference is there...
Here's the new Jim Hall, right off his web site:
"The Stinger Intake is our newest intake system, and is probably the baddest *** intake on the market for the money. It features the same 25% more than stock flow numbers of our TRAP..."
And, here's a picture of the "Halltech Stinger:"
Compare that to the Blackwing:
Notice any, errr...., similarities?
Jim copied the Blackwing (which came first), right down to the filter color, after he had all the headaches with water ingestion back in the original "cold air" days with his now discontinued "TRIC." Some motors blew up and all of a sudden the "lifetime warranty" issues became very real for him. His new "cold air" intake is only recommended for "track use," and I don't know if it still comes with the same wet-suit waterproofing booty he was selling with the TRIC before that thing was completely discontinued.
Another "improvement" he touts is the "Warhead" filter -- the "highest flowing filter" and "least restrictive" on the market. You know why it flows so much? Because it also filters less.
The highest flow, least restriction comes from no filter at all.
There's a reason why the U.S. Army uses your tax dollars to put Donaldson filters on every tank, truck, and HUMVEE in the deserts of Iran and Afghanistan. They work. They "flow." And most importantly, they "filter."
That's the kind of performance and protection I want for my motor.
Finally, regarding your comment that you can't see the benefit of cold ari induction on the dyno, why not?
Isn't the "cold air" coming from the outside, and the "hot air" coming from the hood side? There should still be a difference, shouldn't be there? I think you may have confused the dyno "cold air" effect argument with the dyno "ram air effect" argument. Both benefit greatly when the SOTP meter is used. Can't be measured, but boy, it sure feels like it's faster. Known as the "placebo effect."
Cheers!
There's always a tradeoff on filters...higher flow, less filtering capability and vice versa. This also applies to the Blackwing. Great filter, but the very nature of filters result in a balancing act between compromising flow and filtering ability to an acceptable degree. It's worked for me. I've run a Blackwing for the last four years on my C5.
Dynos are performed many times with the hood up and fans running (blowing air at the car). The difference between air inside the engine compartment and outside is minimal, at best, under these conditions. Therefore, little, if any, difference on a dyno. To my way of thinking, the real benefit of CAI systems is when you are starting from a stop or moving very slowly. For example, I'm planning on installing LT headers and figure this will probably throw a little extra heat load at the engine compartment. If I'm stopped, underhood air temp will rise fairly dramatically, fairly rapidly. That will affect performance off the line. A CAI system, such as the Vararram, provides the capability of drawing in air external to the engine compartment. The fact is, this air will be cooler than underhood air, and probably significantly so. The Blackwing is a great filter, no doubt about it. However, for the above reasons, I'm switching to a Vararam. The intake design appears sound (from a water ingestion standpoint) and I like the (relatively) cold-air draw when the car is stopped or moving slowly. Cooler air does make a difference when launching, no doubt about it.
Ed
This isn't a SOTP observation or any placebo effect from just having spent bucks on a Vararam. Fact, --- with a Blackwing, the air temperature coming into the engine is 2-5 degrees warmer than the outside ambient air.
Using C5Xtasy's formula above, that means that the Blackwing loses about 1 horsepower to the Vararam. Big deal, and it's a cleaner simpler installation in a more water protected location.
And thanks to Ragtop_Rob above (it seems only pilots really understand "forced air induction" and "ram effect" -- because at our speeds and altitudes we live it more than the civilians do), there is no "forced induction effect" or "ram effect" with a Vararam -- unless the supercharger is mounted behind it.
There you have it -- 1hp difference -- you'll never feel it. So, what accounts for those magical 0.3 sec. increase and 2 mph differences after the Vararam install?
It's something called the "placebo effect," well known and well documented with sports equipment all over the world. Nike has made billions as a result.
Cheers!
A biased response from one who just installed a Vararam
The volume (CF/Sec) of air being applied to the devices, would equate to some induced pressure. As the Intake side is acting as a vacumn, the scenario with the greatest pressure differential should permit the most air to move from the high pressure area to the low pressure area. Based on this, the air being introduced (say at 65 mph) at the Vararam intakes should develop a higher pressure (partly induced by the Vararam design and partly by its own speed) than the enclosed are surrounding the Donaldson. This being true only if the Vette design doesn't force ar into this area by design.
OK, I'm sure I'll either be right or flame out. Be kind
Cheers!
All very interesting reading.........
Now here is a fact from someone that actually had both systems on the car. I went from a Blackwing to VARARAM and gained an avg. 3mph and 4/10's. My car is/was a VERY consistent a/4 that ran 12.25's @ 113 ALL DAY LONG for over 1 year. Swap to VARARAM gave me (the only change) VERY consistent 11.81's @116 mph. These gains stayed with me for over one year, racing at different times, days, DA's blah blah blah. BTW, my consistency with both intakes was within 3/100's. Maybe the printer at the track was given a "placebo" just to pacify me for spending $300 on a VARARAM.
For all you nay-sayers that have never done it or even been to the track to test out your "theories", I suggest that you shut your mouth when comes to giving advice until you have "been there and done that".
I find it funny that the fastest N/A C5's in the country run VARARAM. But then again, what do they know, they ONLY RACE THE CARS and can choose any intake they want.
Why does it "sound like it shouldn't"? It only makes sense that cold fresh air makes additional H.P. The Blackwing breathes hot underhood air. The proof is in my post above. But hey, you can listen to guys that have done it, or guys that have not.
1) The physics behind introducing cooler, therefore denser, air into an engine...more oxygen, and not rolling back timing - two benefits
2) Drive your car when it's cold outside and note how it performs vs when it's hot outside. There is a significant difference. That is all due to inlet air temperature.
The Vararam is a sound design. That's why I bought one. The Blackwing is a good design, also. The compromise is it draws underhood air. Using a cold air shroud on a Blackwing will also work except you add the hydolock concern because it draws air from the front dam area. The Vararam draws air from the foglight area. No scooping action like at the front dam area.
Ed
