When cold outside, squeaking from RF
Old Feb 20, 2005 | 11:40 AM
servohead's Avatar
servohead
Default When cold outside, squeaking from RF
Hey guys, what could be the cause for a squeak originating from the right front corner over bumps of my '99 FRC? I'm thinking a shock mount or something like that. It sounds like rubber is involved. Anyone else had this condition? Thanks for your help!
Old Feb 20, 2005 | 11:45 AM
C5 ChemE's Avatar
C5 ChemE
I get squeaks too going over speed bumps in the cold...
Old Feb 20, 2005 | 12:28 PM
JH's Avatar
JH
Me too! Wonda, wonda why?
Old Feb 20, 2005 | 12:30 PM
servohead's Avatar
servohead
Yeah, I'll have to put it on the lift at work to check the RF suspension again. I have a heatshield vibration to fix too. My three guesses are upper or lower shock mount, swaybar link or bushing, or spring mount rubber... not sure why that would make noise but anything is possible. I guess I just wanted to see what the typical noise makers are on C5 front suspension.
Old Feb 20, 2005 | 12:47 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Sway bar link would be the first area to visit. Had the same sound you describe and they were the culprits. The link nuts torque to 53 lbft and the clamp bolts torque to 43lbft. Just try loosening them and re-torqueing.
Old Feb 20, 2005 | 03:12 PM
servohead's Avatar
servohead
mmh. Ok Ill check those swaybar links again to be sure, but the creaking noise definately sounds more rubberish. There isn't supposed to be any grease or lube of any kind in the spring rubber-mounts is there?
Old Feb 20, 2005 | 03:15 PM
sweetcharity
Pull the bushing clamps and check for rust, dirt etc....between the bushing and the sway bar. Clean it up, add a little silicone grease and if that is where the sound was coming from, you will be good to go!
Old Feb 20, 2005 | 04:26 PM
servohead's Avatar
servohead
alrighty I'll try that too.... now off to the lift!
Old Feb 21, 2005 | 06:43 AM
esmachers's Avatar
esmachers
Let us know how your inspection goes. I had the squeak yesterday while it was cold and did a quick search this morning on the forum to see if there were any threads. Funny how things work out....
Old Feb 21, 2005 | 07:00 PM
servohead's Avatar
servohead
yeah it's crazy. Since this thread I posted, there are at least three other suspension squeaking threads that popped up! Maybe C5's all break in the same place at once....
Old Feb 22, 2005 | 07:45 PM
jimcork1's Avatar
jimcork1
Default I have a squeeker Too!
I have already done the sway bar bushings with rubber grease and it did not solve the problem. The front spring with the rubber bushings were also replaced by the dealer,, This left a groaning sound of dry rubber. I used silicon spray lube on the rubber joints at the spring and the noise quit. However the squeek is still there. I think it is a shock. The price of the shock will "shock" you,, unless someone in cyberland has found a deal on C5 shocks for the adjustable suspension. My bet is the shock. I did switch to performance on the ride control and wala,, no squeek. Jim 99 Nassau Blue still squeeking along.
To When cold outside, squeaking from RF
