Instrument Cluster Lighting Problem
Old Feb 20, 2005 | 02:50 PM
gltrap54's Avatar
gltrap54
Default Instrument Cluster Lighting Problem
I'm experiencing a loss of lights on my instrument cluster & audio panel once the car is started. They are fine on accessory, but once you start the car they go out. I'm throwing a number of history codes also. Don't know if there is a connection between these problems. Anyone have a guess?
Old Feb 20, 2005 | 06:35 PM
PaceThis's Avatar
PaceThis
Check to see if your dimmer switch is dimmed all the way...
Old Feb 20, 2005 | 08:24 PM
RonJ's Avatar
RonJ
I think that some codes to do with mirrors, seats, A.C. etc will always show as History even when they are really Current codes. Perhaps you should look into your codes.
Ron ...
To Instrument Cluster Lighting Problem
