Front Wheel Size Question
Old Feb 23, 2005 | 03:02 AM
ostmark's Avatar
ostmark
Default Front Wheel Size Question
Has anyone ever put an OEM rear 18x9.5 on the front of their car ? Just wondering about the offset. Would like to have 18's all around with 275/40 tires.
Old Feb 23, 2005 | 08:50 AM
alssiri's Avatar
alssiri
We have AFS zo6 18x9.5 wheels on a lowered 98 C5 but with 265-35-18 with no issues.
Old Feb 23, 2005 | 08:56 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Many times.......with magnesium rims
275/35/18 & 295/35/18 w/o issue and the tires are inside the fenders.
Old Feb 23, 2005 | 10:12 AM
vetdude's Avatar
vetdude
Depends on the wheel. I have a set of 17x9.5 Mallet 396s on the front of my '99 and the tire sidewall sticks out slightly from the fenderwell.
Old Feb 23, 2005 | 10:18 AM
jdmvette's Avatar
jdmvette
Night Owl for life
you may have issues with stock 275/40s. most 18s up front are 275/35s. the 40-series may be too tall for the AH to be happy, but that depends on your rear tire choice.
Old Feb 23, 2005 | 11:18 AM
shurite44's Avatar
shurite44
I had 285/30/18s on front on 18x9.5 thin spokes. worked fine only thing that would happen is the tire would sort of drag a little when I backed up and had the steering wheel turned all the way left or right. I think it was just from the tire being so wide.
Old Feb 23, 2005 | 11:49 AM
ostmark's Avatar
ostmark
Thanks for the input gentlemen, my local discount tire outlet said there could be an issue and I wanted to ask the forum. Now need to decide on a tire rather than the infamous runflats. Thanks for heads up on the 40 series all around, will put 40's on the rear and 35's in the front.
Old Feb 23, 2005 | 12:29 PM
shurite44's Avatar
shurite44
Hi, here is a link you may find useful in your tire search. You can enter tire size and compare height of different tires. It will also give you speedometer error. It is recommended to have a higher tire in the rear than the front to keep from adversely affecting your active handling. The exact amount of slope needed is a mystery to me but I have seen 1/2 minimum recommended. I think as long as you have some sort of slope from rear to front you will be fine.
http://www.discounttire.com/dtc/brochure/info/tireMath.jsp
To Front Wheel Size Question
