cam patterns????
Old Feb 25, 2005 | 09:21 AM
Z06 Steve's Avatar
Z06 Steve
Default cam patterns????
I'm tring to select a cam for the Z06.What is the single pattern designed to do?the split?and the reverse split?
Old Feb 25, 2005 | 10:48 AM
CNB's Avatar
CNB
I don't want to sound rude but you're better off talking to a performance shop then asking here. Even performance shops disagree on which style works best.
This link may help.
http://www.hotrod.com/techarticles/18218/index.html
Old Feb 25, 2005 | 10:56 AM
Z06 Steve's Avatar
Z06 Steve
tried that but no straight answer either.
Old Feb 25, 2005 | 11:05 AM
CNB's Avatar
CNB
PM sent.
Old Feb 25, 2005 | 11:26 AM
Mitch C's Avatar
Mitch C
Old Feb 25, 2005 | 12:34 PM
Z06 Steve's Avatar
Z06 Steve
undefinedor if this is easier.a good cam for for stock ls6 heads with full bolt ons.i'm looking for a drag strip performer not a dyno queen.limited street.
Old Feb 25, 2005 | 01:12 PM
stano's Avatar
stano
Originally Posted by Z06 Steve
or if this is easier.a good cam for for stock ls6 heads with full bolt ons.i'm looking for a track performer not a dyno queen.limited street.
Subdriver is a member here and he tracks his car in SCCA National events. Look him up and talk to him. I'm sure he can point you in the right direction for you track performance needs.
Try these sites:www.sccaforums.com or www.cc66racing.com
Old Feb 25, 2005 | 02:14 PM
Ttop34's Avatar
Ttop34
From what I know (which isn't much), generally, a single pattern cam has the same lobes intake and exhaust. Split pattern favors the exhaust and reverse favors intake. Your cam needs to match the rest of the package. If your using nitrous for intstance, usually a split pattern is used because your having aid on the intake side. If say, your heads and exhaust system flow really well on that side but your intake isn't so great, you might want a reverse pattern to balance out things.
If I'm wrong, somebody please correct me.
To cam patterns????
