Why staggered wheels again?
You can use the same wheel size all around, no problem...just stagger the tire heights front to rear, otherwise you will have Traction Control issues. Keep the rear tires about 1/2" taller and you'll be fine.
my fronts wheels are 18x11 and my rear wheels are 18x12. I run 25.5x11.5x18 tires on all four corners. the wheels are identical tires and diameter and I have never had AH though a code. I have had AH come on in a corner when I was doing about 70 but I just truned AH off.
And now, I'm planning to run 315/30/18 Pirelli PZero Corsa on 18x10.5s, again, in all four corners and I'm not expecting any problem. Car is still in hibernation mode.
That sounds like a good theory - I've heard about this since I've had C5's, but only changed the wheels on my '03 Z06, and have never experienced any AH weirdness. I've run on track with setups much different than stock (in comp mode) - no problems either.
I have that spreadsheet that circulated that lets you plug in tire/wheel sizes and calculates overall height and front-to-rear variance as a percentage difference. Supposedly, that's the key, is to keep the front/rear ratio the same as stock.
I'm currently running a 275/35, 335/30 on 18's all around with no problems - had the backend get a little loose in the rain, and AH kicked it and worked like it should (even though the spreadsheet shows a 1.9% change) - switching to a 275/35-18 with a 345/30-19 rear which actually indicates a 3% change from stock, though several people are running this with apparetly no problems.
I do wish there was a definitive answer about this - it seems to make *sense* that the AH system would need to calculate front-to-rear rotation differences to sense a problem. Hopefully the new setup won't be a problem!
FWIW, I read that the staggered 17/18 was to keep the smallest diameter possible on front to reduce the height/frontal area while still clearing the brakes (so a 17") and in the rear where that wasn't a concern it was stepped up to an 18 purely for cosmetics.
I'd have to say after having my stock 17/18, now 18 all around, and seeing lots of 18/19 and 19/20 combos, that (IMO) the shape of the C5 is better balanced by having the front to rear staggered fitment!
Cheers!
so this is just my two cents from a engineering stand point. So heance i have staggered wheels on my car.
Good luck and carrie on the debate!
But when it comes to cars there are many ideas on how to make the best and fastest cars. Just my two cents and it is not worth much, just one engineers stand point. But i have made some very fast cars and it was not alway the one with the most hp that wins it is how fast you get to the other end.
I love these cars and love the look of a staggered cars. most of your high end cars have staggered wheels guess i can not be all wrong.
So if it make you happy to have 18 or 19 all the way around go for it.
I thought it was so you couldn't rotate the tires.
Now, the ABS maybe a different thing. I know that it uses wheel sensors, but I don't know if they are coupled with the yaw sensor, which I highly doubt. The out-of-limit of tire ODs may confuse the ABS ECU, but then again in my case, I have never had a problem.
The traction control is simpler, but it maybe the one that compares the difference in rotational velocities of the front and rear wheels. Relatively (to the stock ratio) smaller rear wheels mean faster rotational velocity of the rears, which may cause the TC ECU to think that the rear wheels are spinning due to losing traction. I can imagine that the stock programming (even in full AH/TC mode) will allow some discrepancy in rotational velocity ratio. Whether the system has a learn mode to tolerate minor tire OD changes, I have no idea.
In any rate, my TC never "complained" even with the rears slightly smaller. So, I don't know. What may work in mine may not work on yours.
2003 Z06 here.
Standard on every Corvette, the Active Handling System can actually help correct the vehicle’s direction if the car is not accurately responding to steering input. By combining yaw-rate sensors, the ABS and traction control systems, AHS compares the steering wheel position with Corvette’s actual direction and applies any of the four brakes to help compensate for difference.
just thought I would add....it's only a standard option on '01 and later
Personally I've never heard of anyone having problems, provided the kept the rear size bigger (even if it's a tiny amount) than the front. Personally I run 25.7" fronts and 26.1" rears which is way tighter than stock (25.7 and 26.7 I think) and I've never had a problem.
I HAVE heard of people getting codes from running a smaller, or same size in the rear though.
Maybe we can put the debate to bed forever. AH gen 1 or gen 2 might be the deciding factor.
Don't forget that just because you don't get a code, doesn't mean everything is hunky dory.
On my old Camaro SS (2000 model year), it came with 275/40/17 all around from the factory. I upgraded tires and put 285/40/17 on the rear (with 275s on the front).
Never had codes or any real issues, but the ABS would kick on while braking in a corner. I'm not talking high speed, I'm talking taking an exit ramp and gently braking. You could feel the ABS pulse even though the tires were NO WHERE NEAR slipping. Extremely annoying, let me tell ya. And I don't know how many people told me that going to those sizes would be fine. I went back to the same size front/rear and the problem disappeared forever.
Just a thought.
Dope
