Thermo installed/Lost power??
The temp hovers around 178.
Is the computer changing something?
Any ideas
I disagree with the whole bad thing you are describing without any details. If you provide some details then I might be more inclined to listen. My SS and my GT dont seem to mind the 160 thermo. I have put over 100k miles on the GT and have pulled the motor apart to put higher comp pistons in it and have seen zero signs of any problems.
I really like this forum because you always seem to learn something cool.
So learn me.
"a 160 stat only helps you to lower fan seetings so the fans do not run all the time"
The higher the fan temp settings, the less thay run.
I see in your signature you run a 160.
I do agree in a cold climate I would change it out and run a 180.
Bob
the code was far the coolant not getting above 178 degrees
i guess thats something the pcm is looking for and it wasnt there so it threw the code
NOTHING!! NADA!
Well we can throw the code throwing out the window, at least.
Is this going to be one of those threads that just won't die? By the way, welcome to the forum. Oops, sorry I got off track. I hope Evil will reply cause I want to know more about the 'sweet spot'.
Bob
Bob
In warm climates, the 160 Tstat will open, and stay open once the coolant temp reaches 160. Beyond that, it does absolutely nothing. If you want your car to run cooler, turning the fans on sooner will achieve that..the Tstat alone won't do it.
Anyone with aftermarket valvesprings knows the importance of getting the car up to temp before beating on it. Seems silly to add a mod that only lengthens that wait time to "normal temp", yet does nothing to limit max temps.
The lower Tstat is best used in conjunction with lowered fan settings. If you keep the fans on down to 200, and your stock Tstat closes at 195, both will be a continuous on/off cycle in normal driving...not a good thing. This is the reason you'd want to add a lower Tstat.
Coolant temps of 190-210, and oil temps of 200-220 are considered "ideal". I agree with E-T, running consistantly at temps colder than those will cause more harm than good to the engine.
Why are warm temps desirable? A lot more than just emissions reasons...if your oil temp isn't reaching 200 degrees, you aren't burning off the condensation in the oil, and this is what creates sludge, as well as much increased wear to the moving parts.
Aluminum engines don't have the same expansion/contraction properties as older cast-iron engines...These LSx engines really are at their loosest when warm. Oil thins and flows better when warm, another beneficial thing in the quest of power.
As for power difference....ever give any thought as to why the 3rd of 3 dyno pulls is almost always the highest? (assuming no changes in between pulls). Most any reputable tuner will tell you these engines do perform better at moderately high temps, and dyno's reveal that routinely.
Too many people retain the old carbuerated mindset that a cold engine makes more power. Those days are long gone.
This other guy tore his engine down at 100,000 and it looked good. 180 is not cool. Aluminum will expand quicker and at lower temp than cast iron.
Bob
This is similar to the tire pressure sticker 30 pounds cold on the door... it is just a generic tire pressure sticker setting.. so customers wont use the max pressure settings on the tires,..,, but that 30 psi sticker is just a general statement.. the tires perform best at 30 psi.. but if you set them cold at 30 psi and get out on a Hot black top on a summer 90+ day road where temps can reach 160F, those tires will increase to 36 psi... that is not where they should run... I never allow my tires to get over 30/31 psi "Hot" that's where they perform,, they do not perform at all when cold...so why set the temperature there. Tire pressure is so critical... Nascar pit crews monitor track temperatures all day long and adjust tire pressure accordingly. Proper temps can give you better mileage and more tire life... these are critical in Nascar. A few extra laps on the tires and better fuel economy are all part of a well tuned Nascar. Not as critical to a daily driver, but the concept is the same... I consistently get 33 mpg on the highway with my car.. and I can get 45,000 miles out of a set of tires.. because I know what I am doing.. my car is tuned for me and where I live and how I drive and the road conditions... I have been trying to teach this concept to people here... many have adopted this, and other do not..
I am so..... moving away from posting in open forum and just helping people who know me in pm.. I do not need to argue with anyone.. or qualify my statements to Bullsh}t artists or street racers>
Bob
I guess since you're the one going through the effort to make the car run cooler...you must have a reason?
If temps were high enough that you would get ping or knock, then yes, it makes sense to lower temps.
The only other power benefit I know of to be had with a cooler operating temp, is to lower the IAT. (Intake Air Temperature). Cooler and denser intake air is always beneficial for more power...but with these plastic intake manifolds, heat soak ain't what it used to be, and engine temp now has a much lesser affect on IAT's.
There was a lot of discussion years ago when the tuners started noticing the dyno pull phenomenon. The cars dyno'd higher the warmer they got. To people "in the know", it is generally accepted that cold air into a fully warm engine is the best recipe for hp.
And yet people still strive to make them run cooler. I don't get it.
I said I am always willing to learn
I think I just did. Thanks.Bob
It is interesting to note that with my 99 FRC, the coolant is always 197 when warm, regardless of outside temperatures. Last summer, with the air on, the outside temp was 98 deg and coolant was, as always, 197. When temps are 20 deg out, the coolant is still 197! Have no intention to change stats and fiddle with the fans, it seems the Genreral got this one right!
Edit: I should add that on short daily driving runs in very hot weather lower fan settings and thermostat would keep your car cooler if you are having over heat type problems. But eventually the car will heat up to the same temp regardless of the thermostat and fan settings, it only slows down the process. And cheers again
