new ghl header question
Old Mar 1, 2005 | 09:04 AM
donnyonee's Avatar
donnyonee
Default new ghl header question
im putting on the new ghl headers and i have a problem.
the cats dont seem to get tucked up into the cavity enough, even with a lot of lifting on the x pipe i cant get the bolts to go in the rear mount.
im about 2" too low. do i need to loosen the header bolts on the motor? i wouldnt think theres enough slop there to make that kind if difference.
anyone experienced this?
thanks,
don
Old Mar 1, 2005 | 10:24 AM
rudolph schenker's Avatar
rudolph schenker
I was able to rotate the portion with the Cats upwards in the tunnel , enough so they only hang about 1/2 inch below the tunnel. Then I installed the x-pipe on it's rear hangers. Note,, place your front O2 sensors before you tighten your header bolts, otherwise they are difficult to place after the headers are bolted in. Pm me, or email me if you have any more questions mcritchfield@springairwireless.com.
