FLP Header Install..need some help.
Old Mar 3, 2005 | 09:25 PM
BAD_TCR's Avatar
BAD_TCR
Default FLP Header Install..need some help.
Just bought some headers off a fellow former member LeMansBlue04 . In excellent shape, and a pleasant person to talk to. Anyways.... FLP doesnt have online install instructions. I've asked them few questions, but feel I may get to be a pain in their side. So far from FLP, I've gotten: just remove lower bolt on altenator to move it out of the way, remove FRCs, plug wires, air tube. Drivers side from underneath, passenger from top. One big question I have left. Do the stock manifold bolts work with the new manifolds since they seem to be slightly skinner than stock? Or anybody got any instructions for specifically the FLPs online or scannable? Any help appreciated.
Old Mar 3, 2005 | 09:59 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
http://www.ls1howto.com/index.php?article=17
Old Mar 3, 2005 | 11:08 PM
Diamond's Avatar
Diamond
Cruise-In II Veteran
Cruise-In III Veteran
I used the stock manifold bolts, although I did add 2 small washers so they didnt prematurely bottom out. Worked great. Install was a breeze.
Old Mar 3, 2005 | 11:21 PM
BAD_TCR's Avatar
BAD_TCR
Yeah I saw just that over on z06vette, that the stock bolts are too long. I was thinking about doing just what you did. Glad to know that works. Now I just got to decide whether to get new gaskets. Seeing how my vette is an 04 with only 8k, I'm thinking they might be ok to reuse... Thanks for the help.
Old Mar 3, 2005 | 11:23 PM
'06 Quicksilver Z06
The gaskets should be OK to reuse if they are relatively new.
Old Mar 4, 2005 | 09:37 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
And mine with pics
MINE FROM 11/29/02
Old Mar 4, 2005 | 11:42 AM
BAD_TCR's Avatar
BAD_TCR
Anybody know if I have to use o2simms if I use the straight pipes? OR can I put the sensors in anyways??
Old Mar 4, 2005 | 06:18 PM
'06 Quicksilver Z06
Originally Posted by ALLTHROTTLE&NOBOTTLE
And mine with pics
MINE FROM 11/29/02
Nicely done
Old Mar 4, 2005 | 06:58 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Skip the O2 sims, you really need a tune, and the rear O2's can be turned off in a edit program. Just get some bung plugs.
Old Mar 4, 2005 | 09:22 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The best header bolts ever made are right here Breslin you can buy them thru Jegs also.
Old Mar 4, 2005 | 10:08 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Old Mar 5, 2005 | 12:18 AM
BAD_TCR's Avatar
BAD_TCR
Yeah, but for time being, is installing the o2 sensors and the straight pipes going to throw a code?
Old Mar 5, 2005 | 02:50 PM
BAD_TCR's Avatar
BAD_TCR
Got em all in. Was a pain for the first 5 hours by myself and taking short cuts is a no-no. Finally took parts out I should have, and got some friends home from work, and we knocked it out. Runs and sounds like a totally different beast. My wife's going to hate it. Only problem was an engine misfire on the first run, but went back and checked and the #8 wire had come off. It still doesnt really click hard in place, but its good now, and all test runs have been good. Checking on getting the tune next week.... Thanks all.
To FLP Header Install..need some help.
