Which fuse?
Old Mar 8, 2005 | 10:55 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Default Which fuse?
Which fuse controls the interior lights? Sorry all, I looked through OM and can't find it. I have no map lights, footwells, or cargo area lights. Only thing I found was relay #42. TIA. Everything else is ok (door switches, dash, grea indicator, TC control button, etc.)
Dave Q.
EDIT: Oops. I'm asleep. Mod notified to move.
Old Mar 8, 2005 | 11:04 PM
karshop's Avatar
0karshop
Former Vendor
Default fuse
Dave Q.
look on the fuse block cover, it will say which fuse
Old Mar 8, 2005 | 11:06 PM
MyVetteDream
I did ... not there (that I saw). Thanks though.
Old Mar 8, 2005 | 11:12 PM
circusvargas1's Avatar
circusvargas1
Dave, What you did you do? See what happens when I am not there to get in the way.
Old Mar 8, 2005 | 11:17 PM
MyVetteDream
I dunno what happened? Worked fine a half hour ago. I got home ... all of a sudden, no lights.
Old Mar 8, 2005 | 11:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check fuse C/LALDL Mini fuse# 29, (10 amp) in the instrument panel fuse box. If that is not the issue, relay # 42.
The BCM controls the relay. You can ground the Gray/Black wire on the relay (terminal 690) on the relay and the light should come on.
Any further questions?
Bill C
Old Mar 8, 2005 | 11:53 PM
MyVetteDream
Thanks guys. I was in the garage (handy fuse checker lets you know without pulling the fuse) ... found it ... it was #29 in the footwell. Thanks Bill ... you must be psychic! Lights are back on.
EDIT: I think I figured out what happened. The fuse is labeled "DIAGONISTICS" ... I have a Window Valet plugged in ... I think I hit it with it with my knee ... caused a short, blew the fuse.
To Which fuse?
