1999 memory function ?
Old Mar 9, 2005 | 09:39 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default 1999 memory function ?
Ok i have a 1999 coupe with memory. Also Mary (Grayfox) has a 2003 coupe. When she unlocks the 2003 with her fob#1 her seat moves into position before she gets in. And move to my position when unlocked with fob #2.
On My 1999 my seats do not move to memory position till i put key in. Fob#1 or fob#2
Is my car supposed to move like hers does. We both have window valet is the configuration their. Or is it just a difference in year.
Tia
Brian
Old Mar 9, 2005 | 11:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My 2002 Z06 and 98 coupe act differently. I think it is normal.
BC
Old Mar 9, 2005 | 11:18 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
thank you
Old Mar 9, 2005 | 11:23 PM
GrayC5's Avatar
GrayC5
We do not have the window valet, but our '03 vert does have the memory function. With the Easy Entry option set to SEAT EASY ENTRY ON, ours works exactly like yours and that is the way it is described in the '03 Owner's Manual. I suspect the difference may be in the way Mary has her Easy Entry option configured and the postion of the driver's seat when the last driver exited the vehicle. The Owner's Manual (page 3-53 for the '03 model year) contains more information on the configuration and how the Easy Entry option works. Hope this helps.
Old Mar 9, 2005 | 11:36 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
nothing in the 1999 manual with same wording as hers it must be different.
Old Mar 9, 2005 | 11:59 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
my 97 acts like your 98 - moves when key is inserted.
Old Mar 10, 2005 | 01:02 AM
blackbelt's Avatar
blackbelt
same here.
Old Mar 10, 2005 | 08:06 AM
purrvert's Avatar
purrvert
2000 here, moves into position after key insert. The purpose of easy entry is defeated if the seat moves before you get in.
To 1999 memory function ?
