15000 mile oil
"Use the Freekin OIL Life Monitor" it took many months of time and research and thousands of dollars to develop...specifically for YOUR car
or you can listen to Grand pop and what he did in the fifties with his Buick Roadmaster, when engine life was around 60,000 miles.
My 98 C5 and 01 Grand Prix get oil changes by the indicator. Oil analysis tells me the oil still has useable life when I do change it!!
Ron ...
OLD HABITS of 3k are hard to let go of. The dealers, and petro companys love you 3k guys. The sad part is you are not helping your engine just the petro companys.
The owners manual even says up to 7500 miles on an oil change. Mobil 1 only. I think everyone is paranoid with the oil change question. This has been the most talked about issue thread on this forum for no apparent reason at all. Just use the DIC and reset it at oil changes.. Easy as pie. The DIC will tell you when you are down to 10% of usefull life
I will also replace my tires when they get dirty.
Technology of engines and oils has change dramatically since then, but Old Wives Tales die hard.
It feels good to change it. I feel it is running better and will last longer even if it is a cement mixer
That's part of the problem.
Why is it so hard to understand that technology, oil and in general, has progressed from the days of old? Just because our grandparents changed their oil at 3000 miles doesn't mean we need to.
Do those that refuse to trust the oil life indicator also totally deactivate the ABS, traction control, active handling, climate controls, air bags and so on. Do you also refuse to even drive the car because you don't trust the fact that so many operations are controlled by computer? Of course not. Yet the particular function to accommodate the fact no oil ever was always good to 2999 miles then suddenly went "bad" at 3000 seems to cause angst to so many.
There was a time when the general case of changing your oil at around 3000 miles was probably a reasonable thing to do. However, we've moved on. Man has now gone into space, the computer mouse has been invented, we no longer use punch cards and paper tape for computer input, Random Access Memory is everywhere, hand-held calculators have been invented, we now have computers that are even smaller and dwarf the capabilities of even the biggest of some decades ago and, of course, we now have have the Internet.
Oil technology has improved too.
Why is that so hard to believe?
Guess what, engines were not ruined.
Then people started going 3000 miles before changing,
WHAT WERE THEY THINKING? Now, since the early 90s, most manufacturers began going to 7500 mile recommended oil changes, and 15000 mile recommended changes are now upon us. The push behind this was enviromental impact, lessening the crude oil requirements for motor oils and fuels, and reducing the waste oil impact was a goal that the engineers faced, and met. The proliferation of synthetic oils helped reduce the need for dino motor oils, but the waste product remains regardless of type of oil used. Therefore the best way to reduce the waste oil product was to develop longer intervals. With the introduction of electronic / computer controlled fuel delivery, spark control and leaning of the fuel ratios, the old problem of fuel washing of the cylinders, and the resulting oil contamination was greatly reduced. How many here remember pulling the dip stick and being able to smell raw gasoline in the oil, or lighting the oil on the dip stick? I doubt if anybody is having that problem in today's engines. Additionally, with higher running temps, moisture is usually boiled off with a drive to work every day, as long as the distance is great enough to allow the engine to reach full operating temperature. Because of the reduced moisture, acids are reduced and therefore the oil life becomes much greater than that of 40 years ago. Now there may be those out there who do need to change the oil and filter more often, but for probably 95% of us, we can go with the oil life monitor as our guide, note I said GUIDE.
So it all really boils down to individual preferance. Technically speaking, those who are changing their oil and filter at 3000 miles are doing so because they feel they need to, that's their peace of mind. For those who follow the oil life monitor, that to me is good sense, and as we already know, it's recommended in the owners manual. For those who track their cars, my guess is they probably are using some sort of outsourced oil life monitoring program, and are changing their oil often anyway. So that's my two cents worth, and a look back on changing times.
zo6vettepilot
An oil analysis, done by Terry Dyson, will provide much information on how your oil and motor are doing.
That's part of the problem.I'm also not so sure TBN numbers mean much as they keep changing the standard.
I have been in the oil business for over 20 years. In the days when I worked for Exxon R&D on engine lube oils, we tested oils in many bench engines which ran at loads and conditions way beyond that of the corvette engine, which is a relatively low-powered, lazy big engine that carries a lot of lube oil in its crankase.
Fresh oil is not at its optimum performance until a couple of thousand miles under its belt.
Very few of the Lube oils components will have had a chance to get working in the first few thousand miles. The combination of heat and pressure is the essence to the antiwear additives in the lube to start depositing in the surfaces they are designed to protect. The viscosity modifiers are designed to take their time to shear down and become effective products.
For that reason folow the GM oil life indicator or the handbook. The additive companies spend million developing products to meet the manufacturers needs. In europe oil changes for many high performance vehicles is set at 17,000 miles.
I have been in the oil business for over 20 years. Fresh oil is not at its optimum performance until a couple of thousand miles under its belt.
Bingo!
The last time this was brought up it was met with a lot of derision by the 3000 mile guys. I have read the SAE paper on this pointing out oils are at their best after several thousand miles. Unfortunately the article was on paper and it wasn't mine so I can't lay my hands on it. But changing oil at early intervals seems to be counterproductive.
