15000 mile oil
Some the additives in high performance lube oils may not meet these specs, so they can't carry that specific standard on the can.
Oil formulation is often about comprimise, For example high level of detergent and dispersant can have an impact on the oil seals. Just chucking lots additives in to the lube oil formulation is not the answer.
The new Mobil 1 Extended Performance doe not meet GM Standard 4718M, which my owners manual states is the requirement for the C5/Z06. But, their normal Mobil 1 does meet this standard. Why their supposedly higher performance oil doesn't meet this standard is beyond me.
The new Mobil Extended Performance would exceed the std had Mobil chose to place it on the bottle .
To you guys who don't think any of Mobil's synthetics were long drain capable I'd like to point out their oil thru the 70's was capble of 30k miles but limited by engine deisigns of the era , mostly due to carbs setting on top manifolds with poor cold start systems " chokes " .
I can list quite a few 10-15k analysis's of Mobils Tri-Synthetic made in the late 80's thru the 90's with can filters and 30k and over mile intervals using bypass filters and one 18k SuperSyn interval from a LS1 .....Amsoil did not make it that far in the same engine and the Amsoil pricing was 2 dollars more per quart . Also that engine was still breaking in early on in the Mobil test while the Amsoil had the luxury of running in that engine's sweetspot of life/mileage .
Price vs performance no-one beats Mobil in my view based on analysis's I've reviewed so no wonder GM , MB , Porsche , Viper and more chooses Mobil synthetic as their factory fill .
This is just the first time Mobil has marketed their oils as long drain capable and the new products have shaken the industry up a bit . This oil is simply outstanding and is still the only true synthetic that is offered over the counter . Speaking of :
They have a new Clean 7500 Synthetic Blend with a 7500 mile performance guarantee that is selling for $2.18 per quart . It's PAO/groupIII which qualifies to be as much of a synthetic as other non real pao/ester oils with " synthetic " on the label such as the group III Amsoil , the new Pennzoil which uses a GTL process , Valvoline , Castrol and more at 1/2 the price .
Back to Mobil's synthetics . They are using newer multiple cutting edge additives in all their oils that work synergysticly together with some of the finest true synthetic base oils on earth while Walmart can still sell 5 quart jugs for 23 bucks .. saying Mobil is an efficient company selling in a competitive market . A top tier product at lower price than lesser oils that have not changed their basic formulation approach in over a decade .
Go Mobil !
Aren't aviation piston engines desgned with quite loose tolerances? If so that wouldn't be a good Mobil 1 application. I don't think it would be good for any application that sacrafices oil like 2 cycle piston or Wankel engines. I know my RX7 specifically stated that you should not use synthetic as oil was sacraficed for the seals.
Mobil 1 states that it isn't reccomemnded:
"Mobil 1 is not recommended for 2-cycle or aviation engines, unless specifically approved by the manufacturer."
Just as an aside I see that The GM "Corvette" spec is now on 0w-30 5w-30 and 10w-30 Mobil 1. I was under the impression that it used to be only on 5w-30.
Couple of links to read:
http://www.prime-mover.org/Aviation/...ins/sl229.html
and
http://www.avweb.com/news/profiles/182855-1.html
"What was your first clue that something was wrong with Mobil 1?
We were seeing Mobil 1 engines that would have real good wear metal profiles, and then all of a sudden things would start up -- no particular break in the profile, just everything would start up -- and we believe that's when those engines started to develop sludge. But that was a short-lived situation. Mobil bit the bullet on that right quick. "
In the Corvette owners manual if that spec oil is not available in other countries plain Xw-30wt dino is allowed .
And yep , the Corvette does not use Lycomings in them and it ain't still 1994 either
EHS ,
Aviation oils are formulated in stark contrast to passenger car engine oils . Difference is nite and day in the add packs .
What happened when Chevron's LL 100 had a dose of Jet A accidently dumped in a load since this is now a airplane thread ?
Mobil delivers . But so does Synergyn 3w-30 and 5w-30 . The latter brand does a better job though
Not sure if that is really true. In response to a query to Mobil about their new Mobil 1 Extended Performance 5w30 meeting GM Standard 4718M, Mobil responded, and I quote:
"Mobil 1 EP does not meet GM4718M."
So if this spec is "no biggie because any group III formulated synethic can meet it", then why doesn't Mobil Extended Performance meet it? And if it does, then why do they say it doesn't?
As I've said before, I honestly don't know what GM Standard 4718M is, but I do know my owners manual says to use an oil that meets it. So as a supporting vendor, I'm going to do my best to keep my recommendations in line with that GM Standard.
If you ever find out why the new and supposedly better Mobil 1 EP doesn't meet the standard for the Corvette, I'd be interested in knowing. Thanks.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
4718 dates back to API SG . Then API SJ and SL and now the current API SM .
All that 4718 has to do is meet those API specs "and " the current sequence protocol testing , like Sequence IIIE , IIIG .
The max Noack allowed for API SL dino was 15 . 4718 had to be 13 or lower AND meet whatever the current API phosforus cap limit .
The phos cap for the 2005 API SM is lower than API SL which ran from 2001 thru April 2005 . Phos cap means max allowable phos used in formulation .
The new Mobil Extended Performance has phos amounts more inline with what API SL had . Noack is the same or even better than SL Supersyn was so since Mobil plays by the book they do not list the new oil as meeting 4718 since the phos additive " anti-wear" is higher than allowed for API SM .
I would not scrutinize the Mobil oil and what they say their oil does or does not meet as much as I would the Amsoil you sell because Amsoil does not submit their pao oils for API lisensing , period.
To conclude , if any of those 30wt Amsoils has more than .08 percent phos they cannot meet current API SM-4718M in my view .
Thanks for the info. I appreciate it.
One minor comment though. The new Mobil Extended Performance is not API licensed either... likely for the same reason the AMSOIL PAO synthetics are not API licensed.
-Sean
