Damaged speaker
Old Mar 10, 2005 | 09:43 PM
WildBill_64's Avatar
WildBill_64
Default Damaged speaker
Damaged driver speaker cover with my combat boots. Can I push the dent out without removing the door panel? If, not a link to "how to"
Thanks ahead for your help,read this forum everyday, great people. Wild Bill
(Retiring next month, 39 years of military flying and now plan to just fly (cruise) in my vette.
Old Mar 10, 2005 | 09:59 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Congrats sir It's not difficult.
Here's a link to door panel removal ... don't say I never gave you anything
http://www.vetteessentials.com/instr...or_handle.html
Dave Q.
Here's the pic ... there are just several tabs you have to starighten. They're pretty stiff though. Take you time.
Old Mar 10, 2005 | 10:01 PM
Vate's Avatar
Vate
There is no way to remove the grill without removing the door panel (well, not without mangling it). You might be able to reach in behind the grill without pulling the door panel off completely, just pulling the bottom out far enough that you can wedge your hand behind the grill.
Here are great directions to taking off the door panel. If it is your first time, you will break at least one of the pins, so you are better off buying some ahead of time at a Chevy dealership, or at Auto Zone, Pep Boys, etc.
You can find some cheap door panel removal tools here. These will help keep you from breaking pins or grommets.
Old Mar 10, 2005 | 10:12 PM
LoneStarFRC's Avatar
LoneStarFRC
And the grills are available as a seperate item if you can't get the dents out. HTH
Robert
Old Mar 10, 2005 | 10:13 PM
WildBill_64
Thanks, great info. What length are the pins as I will plan ahead now...
Thanks, WildBill
Old Mar 10, 2005 | 10:46 PM
LoneStarFRC
Thanks, WildBill
All the door panel retainer pins are the same length and as I recall they are approx 1 1/4" long (males). The female side snaps into the holes in the door itself and almost never have a problem. It's the males, mounted into the door panel that are the easiest to break. HTH
Robert
Old Mar 10, 2005 | 11:32 PM
Speedway's Avatar
Speedway
There is also another method that I discovered and tried myself with success. Locate some fine gauge music wire. Bend a small loop at the end and feed through the grill. With some finagling, you should be able to wrap the wire around the mesh and pull the wire through. With both ends of the wire sticking out along with a pair of vice grips, clamp down on the wires and pull the dent out. You may need to do this several times.
Good luck.
To Damaged speaker
