Blower motor problem
Old Mar 11, 2005 | 07:46 PM
JordonMusser's Avatar
JordonMusser
Default Blower motor problem
'00 C5, coupe. blower motor doesnt come on, even with high fan setting. doesnt matter whether its in auto or manual mode, AC or heat.
checked the fuse.
any ideas??? thanks
Old Mar 11, 2005 | 09:12 PM
Sixants's Avatar
Sixants
First you need to test your controls. No matter what some air should be coming in. If you turn it to heat does it get hot? If you turn it to cold does the air get colder? If it does, then your head unit is okay and you will need to replace the blower motor. Approx. $70.00. Takes about a half hour to replace, one of the easier fixes. It is located above your interior passenger fuse panel. Pm if you have any questions. Good luck!
Old Mar 12, 2005 | 12:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
To test the motor, simply ground the housing with a piece of wire to ground. If the motor is good it WILL come on in HIGH speed. Trust me!! I found out the hard way!!!
There is a control module for the motor. I will look in to it mor later tonight!
BC
Old Mar 17, 2005 | 11:06 PM
JordonMusser
Yea, I was hoping there was a way to check the blower motor/module/ etc without pulling it out and physicall testing it.
Old Mar 17, 2005 | 11:17 PM
BEEN THERE's Avatar
BEEN THERE
just take the blower motor cover off, it only takes a couple of minutes
Old Mar 17, 2005 | 11:21 PM
JordonMusser
good deal, so its not hard to get to. where is the cover, I assume under the glove box/above pass kick area?
Old Mar 18, 2005 | 12:03 AM
BEEN THERE's Avatar
BEEN THERE
under the glove box, JUST A COUPLE OF SCREWS.oops caps, do you have a manual?
Old Mar 18, 2005 | 03:40 AM
JordonMusser
no manual, but ill figure it out :-D
Old Mar 18, 2005 | 04:45 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
Yea,, you can test the motor inplace. All you need to to is remove the lower dash cover and the blowre motor is up undre the dash. You will just about have to crawl into the passengers foot well and look up to see it.
Here is a picture of it.
It's under that piece of brown foam stuff!
To Blower motor problem
