changing headlight bulbs
Old Mar 27, 2005 | 12:59 PM
99Magnetic's Avatar
99Magnetic
Navigator
Default changing headlight bulbs
What is the best way to do this? Have used the ***** to open both, can get the high beam bulbs out by turning them ccw, but the low beams dont seem to go either direction. Owners manual says ccw on both, but have been told low go cw. Any assistance would be appreciated.
Old Mar 27, 2005 | 01:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just got done doing this a couple of days ago. While installing my VARARAM, I figured it was a good time to install my silverstars! I jacked up the front, crawled under and removed the front facia close out panels just ahead of the front tires. There are 5 screws and the panels will come off. It smooth sailing from there. You can even pull the front of the air ducts back and push them aside for even moor room! With the head lights up, you will have good access to the bulbs. CCW is correct. Mine were very tight!
BC
Old Mar 27, 2005 | 01:58 PM
99Magnetic's Avatar
99Magnetic
Navigator
Thanks. Wondered if I could come up from below. .
Old Mar 28, 2005 | 12:03 AM
PetalBombC5's Avatar
PetalBombC5
I installed Silverstars a couple of weeks ago. Found that it's a lot easier to get your hands in there if you unscrew the rubber hood stops. Should be CCW for the low beams as well if I remember right. Hope this helps
Old Mar 28, 2005 | 06:35 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I just reached in from the side.....biggest thing is be very careful and get them seated correctly...very easy to bend the little tabs..then you got a whole new project....trust me
To changing headlight bulbs
