Code C1287 Steering Sensor rate malfunction. Any Fix?
Old Mar 28, 2005 | 11:45 AM
DRK-SYD's Avatar
DRK-SYD
Default Code C1287 Steering Sensor rate malfunction. Any Fix?
My car throw's this code when moving or sitting still. Have any of you had this problem. I did a search and didn't pull up much. While driving the car will pull slightly to the right or left and ACITIVE HANDLING is displayed on the DIC. Also while breaking the pedal flutters and ACTIVE HANDLING is displayed again. It is really making me nervous when driving, I don't want it to pull me into the wall or anything so I just disengage the whole system. Any help would be appreciated before I break down and take it to the dealer.
Old Mar 28, 2005 | 02:10 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
You might have two things going wrong at the same time. When my '99 showed the 1287 code, it was the steering position sensor at the bottom of the steering column that had gone bad. Not an easy fix, requiring column removal to replace it. As to the pulling to the right or left and the Active Handling display, that might be signs of another malfunction (such as a front hub assembly going/gone bad?). I'll let someone else chime in on that one, since I have not experienced that.
Old Mar 28, 2005 | 02:49 PM
ProDesign's Avatar
ProDesign
Steering Sensor Info
http://www.sensorsmag.com/articles/0200/28/main.shtml
Old Mar 28, 2005 | 04:21 PM
DRK-SYD's Avatar
DRK-SYD
Thanks for the replies, that is exactly what Jayson at MTI said. I'll be dropping the car off on Friday for the fix. Hopefully nothing else will pop up. Thanks again.
To Code C1287 Steering Sensor rate malfunction. Any Fix?
