Codes after header install
Old Mar 28, 2005 | 07:00 PM
jefsvet's Avatar
jefsvet
Default Codes after header install
Hello,
I installed a set of FLP long tubes a couple of weekends ago. Now I am getting code P0140 and P1415. I know these point to the AIR system bank 1, but I am wondering what I need to do to resolve the problem? I am using O2 simms in place of the rear O2 sensors, could this be the problem? Any ideas?
TIA,
Jeff
Old Mar 29, 2005 | 11:20 AM
jefsvet's Avatar
jefsvet
Anyone?
Old Mar 29, 2005 | 12:24 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Yep my dynatechs threw those codes after being installed as well along with a check engine light although the car was running perfectly. I was told that the codes resulted from the front 02 sensors being located farther down the headers than stock. Dont know if this is true. Regardless, as long as the car is running properly and there are no signs of problems such as no oil pressure, temps are all normal, car accelerates fine, then just clear the codes. I was advised to clear the codes. After clearing, the codes did not come back.
Old Mar 29, 2005 | 04:09 PM
jefsvet's Avatar
jefsvet
Thanks for the reply. I cleared the codes, but they keep coming back. Guess I need to get to a tuner and have the codes removed? Anyone else have this problem and a solution?
Old Mar 31, 2005 | 05:45 PM
vetred's Avatar
vetred
Default Codes??? AAAHHHHHHHHH!!!
Who knows?, Although I do remember the similar situation being fixed (right here in the FORUM) by making sure that "the right sensor hooks up to the left side! and the left sensor hooks up to the right side! Its just one (out of billions) of the possibilitys but,,,,, It did it for me
Old Mar 31, 2005 | 06:04 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
I had codes deleted via ls1 edit
To Codes after header install
