Magnecore 8.5MM Question
Old Mar 29, 2005 | 09:49 AM
forloop's Avatar
forloop
Default Magnecore 8.5MM Question
I just ordered some magnecore wires from LPE. The guy there told me to get the ones with a 45 degree angle on the boot since I am installing headers. The LPE PN 85259.
I was wondering if anyone is running these?
Thanks,
Old Mar 29, 2005 | 09:54 AM
stano's Avatar
stano
Thanks,
I used to have them. Did a scan with my EASE and found I had misfire codes.Tuner said to get rid of them. I did, put the stock wires back on and no more misfire codes. Maybe it was just a bad wire in the set. The car runs fine now with the stock wires...H/C header set up.
FWIW
Old Mar 29, 2005 | 10:03 AM
forloop's Avatar
forloop
FWIW
If I had a choice I would keep the stock ones. I won't say why I don't have a choice.
Thanks,
Old Mar 29, 2005 | 10:40 AM
stano's Avatar
stano
Thanks,
You ordered them and you don't have a choice..??
By the way, I put header "socks" on my stock wires. I'm running Kooks headers.
Old Mar 29, 2005 | 10:54 AM
nsmith80's Avatar
nsmith80
I put them on last week along with NGK TR55-IX's and haven't had any problems. It seems to be running as smooth or smoother than it did with the stock setup.
Old Mar 29, 2005 | 07:07 PM
forloop's Avatar
forloop
I pull one apart getting it off the plug. My hand slipped and I yank the wire.
I did pick up some ac delco iridium plugs today to go with my new wires.
Old Mar 29, 2005 | 08:02 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
From what I understand, If our stock wire are not cracked or broken, replacing them with Aftermarket wire will not do anything. They are to short, from what I have read here.
Old Mar 29, 2005 | 09:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Very True!!! No HP gains with wires unless your old ones are BAD!!!
BC
Old Mar 30, 2005 | 01:10 AM
DsC5's Avatar
DsC5
To Magnecore 8.5MM Question
