h.u.d conversion?
Old Mar 29, 2005 | 02:39 PM
gamisou's Avatar
gamisou
Default h.u.d conversion?
For anybody that completed the install, how did you get the gauge cluster to read the correct mileage. Also is the mileage is only stored in the cluster or does something else hve to be corrected as well.
thanks Steve
Old Mar 29, 2005 | 02:54 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
The gauge cluster will have to be programmed if that is what you are asking. The new cluster can be programmed to reflect your current clusters mileage. If you need somebody to do this, try contacting forum member Pacethis (Josh). He has the programmer to do so.
Old Mar 29, 2005 | 03:14 PM
sugarwolf's Avatar
sugarwolf
yea does anyone know what all parts will i need to do a H.U.D conversion?
Old Mar 29, 2005 | 03:50 PM
gamisou's Avatar
gamisou
thats the only thing neede to be reprogrammed? If i don't want to spend the money to correct the mileage will it still work in my car.
thanks Steve
To h.u.d conversion?
