quarter panel removal
Old Mar 31, 2005 | 06:15 PM
WLDHRSE's Avatar
WLDHRSE
Default quarter panel removal
Hey ya'll,
This is my first time in tech section.
I want to disassemble the body on my 02 Coupe. The GM service manual says that I have to cut the quarter panel in the area where the painted roof piece comes down in between the door window and back window. It says you have to cut out that area to get to a screw or two holding the 1/4 panel in place. I don't believe this could be accurate considering if these screws were inaccesable, how did they get in there?
Can somebody in here let me know how to remove the 1/4 panels propperly.
Thanks,
Cliff
Old Mar 31, 2005 | 07:03 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
either that or pull the top off....
FRC Tom on here or Z06vette.com can show you his whole car apart..and he did cut the piece you are referring to..
Old Mar 31, 2005 | 07:06 PM
pewter99's Avatar
pewter99
http://www.c5frc.com/photogallery/Paint/paint.htm
http://www.c5frc.com/DIY/Engine_Remo...ne_removal.htm
Old Mar 31, 2005 | 09:46 PM
SpeedyZ's Avatar
SpeedyZ
Are you sure your reading the section of the manual for the coupe? I'm pretty sure that only the FRC (hardtop) has hidden screws on the fenders. Look at the manual again make sure your reading the coupe section.
And yes, on a FRC GM puts on the fenders installs all the screws and then glues on the top covering 5 screws! Way to go GM!
Old Apr 1, 2005 | 12:11 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Remove the corresponding tail lamp from the side you are removing.
Inner back structure, there are roughly 4 bolts holding the back of the panel to the rear bumper. Should be 10mm
Remove tire from corresponding side.
Remove 3 T-15 screws from door sill area holding fender on.
Remove 9/32 bolt from inside of the fender well that holds panel secure.
There are 2 10mm bolts holding the lower rear of the panel secure. They are a pain to get to unless you are in the air, or the rear bumper is removed.
Should be approximately 4 T-15 Torx bits holding the top of the fender to the body pan.
Old Apr 6, 2005 | 08:21 PM
WLDHRSE's Avatar
WLDHRSE
Thanks guys. I'll let ya know how it goes.
Almost forgot...
Is the roof piece between the glass top and back window glued on? If so, does anybody have a good moethod for removing it?
BTW, I'm taking this car apart to paint it.
Cliff
Old Apr 8, 2005 | 06:39 PM
WLDHRSE's Avatar
WLDHRSE
To quarter panel removal
