coolant bypass??
Old Apr 6, 2005 | 04:58 PM
silver04's Avatar
silver04
Default coolant bypass??
I did this on my old mustangs but are you guys doing this to your vette's?? also I wanna run a 160 thermostat. What if any problems will it cause to the cpu??
Old Apr 6, 2005 | 06:17 PM
vettenuts's Avatar
vettenuts
My personal opinion is the 160 is too cool, unless you are in the southwest or something. I kept the stock stat and reprogrammed the fans with a Vinci fan controller with both fans on at 208 and off at 201. Oil temps max out at about 215 on a hot day. As for the bypass, don't think it is worth anything on a C5 especially if you see how little a pocket for coolant there is in the throttle body.
Old Apr 6, 2005 | 06:38 PM
George8211's Avatar
George8211
Too low... your oil likes to live around 200 degrees or more. A 172 is about as low as you want to go.
Old Apr 6, 2005 | 07:01 PM
wlxx861's Avatar
wlxx861
Default Tomball
This dude lives in Tomball, TX it gets hot down here. I live in Houston and run a 160 thermo with my fans controlled using LS1 edit. 193 on; 183 off. No by pass. Do whatever you need to do to keep your car running between 180 and 190. It will run better and will love you for it. Your oil temps will run from 199 to 215 if you beat on it.
Old Apr 7, 2005 | 02:35 AM
Special K's Avatar
Special K
Old Apr 7, 2005 | 03:48 AM
George8211's Avatar
George8211
Last I checked... 160 degrees in Texas, was the same as 160 degrees in Alaska.
Old Apr 7, 2005 | 05:04 AM
vettenuts's Avatar
vettenuts
Where does your oil run with normal driving?
Old Apr 7, 2005 | 07:49 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
THat TB coolant line serves a purpose!!!! It stops the butterfly from sticking on colder days! This mod will not get you any real power.
Old Apr 7, 2005 | 08:14 AM
wlxx861's Avatar
wlxx861
I agree, the thermo has little to do with lowering temps. It only opens at that temp so water can circulate to the radiator. It's the fans that make the big difference. When air passes over that hot fluid it re-cools it for its return trip to the engine. Control your fans and you will control temps.
Chas.
Old Apr 7, 2005 | 08:18 AM
wlxx861's Avatar
wlxx861
Default Oil temp
I run 199 to 207F on the hottest of days. 215F happens when I beat on it. I never beat on my engine when it warming up or below 190F.
Chas.
Old Apr 7, 2005 | 09:08 AM
Special K's Avatar
Special K
It won't run 160 in Texas. 175 to 180 on the highway. Oil will be around 210. My fans don't come on while on the highway due to the 160 thermostat. It will depend on the condition of the cooling system.
Coolant bypass is a waste of money.
Bob
Old Apr 7, 2005 | 09:46 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Got my coolant by-pass parts and hood seal at Home Depot for $3.98. Got to be good for at least 10 HP.
Old Apr 7, 2005 | 10:13 AM
Special K's Avatar
Special K
Maybe 20 HP. Whatever makes you feel good.
Bob
To coolant bypass??
