trans temp
Old 04-12-2005, 08:07 PM
gmosley
gmosley's Avatar
Default trans temp
what is the norm for trans fluid temps under normal driving
stop and go and what not as well
Old 04-12-2005, 08:22 PM
screw991le
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
160-200 for my A4, depending on cruising or stop and go.
Old 04-13-2005, 02:45 AM
Ironswims
Ironswims's Avatar
St. Jude Donor '11, '13, '15, '17, '19
Old 04-13-2005, 04:56 AM
hrdtopv8
hrdtopv8's Avatar
Old 04-13-2005, 05:17 AM
davette
davette's Avatar
If it's over 90 degrees outside and your car is doing alot of shifting, you might see 225. However, normal driving temps are as stated above. If you are seeing temps consistently over 220, you need a trans cooler.
Old 04-13-2005, 09:18 AM
2000BSME
2000BSME's Avatar
I raced up mountains many a time in 2nd gear, and I would get trans overtemp warnings at about 270*F. I installed a cooler immediately and now I don't ever see more than about 170*F.
Old 04-13-2005, 09:49 AM
zeusoftexas
zeusoftexas's Avatar
The motor runs at 220-230 on hot day. The A4 tranny is cooled through the radiator. I can sit in traffic and watch my motor warm up to 220 and my tranny will slowly warm up to 200-210. I think the heat from the water cooling the motor causes the fluid in the tranny to heat up. I'm adding a cooler just to test my theory.
I found a small unit from Earl's it is smaller than the B&M type but has more surface area. It uses cores + fins instead of the tube+fin arrangement. Motor is good to go running at 220-230 but there is no reason for the tranny to run that hot. Heat is the worst enemy of any hydraulic system.
I'm try to post pictures and results when it is done.
To trans temp
Quick Reply: trans temp
