ground strap help!!!!
Old Apr 15, 2005 | 07:33 PM
Fastbasser's Avatar
Fastbasser
Default ground strap help!!!!
I pulled a bonehead...... I am lucky enough to have access to a friends shop to put in my new motor.
As luck would have it, I had a couple of friends help me drop my front end to set in the new motor. Though the said "all clear",,, I found the braided ground strap om the floor. It was hooked on the sub frame when I raised the lift and no one noticed...
I cannot find where it was torn from. (was torn on an angle and was a straight tear) To say this is pissing me off is an understatement. Any help with this would be greatly appreciated..
Thanks in advance!
Old Apr 15, 2005 | 08:02 PM
T_Vert's Avatar
T_Vert
if its on the driver side its just below the motor mount on the block I believe. There shoudl be a wire and a braided line there.
Dave
Old Apr 15, 2005 | 08:26 PM
ditty22's Avatar
ditty22
Mine broke at the drag strip last summer and i had to trailer it home
Old Apr 16, 2005 | 07:45 AM
Fastbasser's Avatar
Fastbasser
Found it.. Its under the brake booster...
To ground strap help!!!!
