Haltech Stinger install
Old Apr 23, 2005 | 01:31 PM
Darion's Avatar
Darion
Default Haltech Stinger install
Ok, installed my Haltech Stinger today and before I get flamed with, “this post is useless without pics”, I have no digital camera but I’m working on it. Mods suck up my money, I'm hopelessly addicted.
Everything was perfect out of the box and the instructions were good. Total time took about 1 hour 20 minutes because I cleaned all the newly exposed plastic and did a lot of test fitting so the hood would close completely. This install could be done in less than 30 minutes if you just fly through it.
Fit was good for my kit and it does not push up the hood like some have posted, but this came after some adjustments. First, get all fitments to go together as tight as possible and flush as possible. Second, make sure that your MAF is not pushing down on the plastic that is under it. If the MAF is turned to much counter clockwise, looking at it from the engine not the front, the square piece that is under the MAF plug will push the entire assembly up, this happened in my case. Turn the MAF until that is no longer making contact. in my case this was about a half inch and the whole unit, air bridge and all, will drop down a bit. Lastly, adjust the assembly front to back as needed by loosening the coupler and adjusting. Great fit in my case, hopes this helps.
Well, to driving impressions, I have none. We are expecting snow in NE Ohio and it has rained all day today. I will say this, the unit sounds nice, can hear the air just getting sucked in. Also, seemed to rev smoother but that could be a reach I’m not sure.
Overall very happy with this mod and I will post a driving impression when I can.
Darion
Old Apr 23, 2005 | 02:33 PM
allanlaw's Avatar
allanlaw
Darion
If you started with a stock airbox, you will feel the difference when you get to the other side of 4000rpm
Old Apr 23, 2005 | 03:00 PM
Darion's Avatar
Darion
Yep, started with the stock box. Can't believe how big and restrictive looking that thing was, I don't know how air flowed through that stock filter either.
Old Apr 23, 2005 | 06:37 PM
Darion's Avatar
Darion
anybody out there?
Old Apr 23, 2005 | 06:47 PM
c5freak's Avatar
c5freak
I like my Halltech. Mine originally had the titanium pipe thru the shroud and was a bottom breather. I converted it to a top breather using a different filter but left the hole in the shroud.
I can convert it either way (top or bottom intake) in a few minutes.
I'm impressed with the high quality materials of the Halltech unit.
Old Apr 23, 2005 | 07:46 PM
Devils Elbow's Avatar
Devils Elbow
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
My Halltech filter works great with a Magnuson.
Old Apr 24, 2005 | 01:37 AM
timf1954's Avatar
timf1954
Sounds like you did a great job. Unfortunately I'm one whose does push up the hood a bit. My radiator is sitting just a little high due to some event in it's previous life. I'll have to see if I can lower it a bit.
Old Apr 24, 2005 | 09:50 AM
Darion's Avatar
Darion
thats the direction I'm going.
Darion
Old Apr 24, 2005 | 12:03 PM
c5freak's Avatar
c5freak
Looks nice, Elbow.
Old Apr 24, 2005 | 06:57 PM
Dave68's Avatar
Dave68
Great job and install tips. Welcome to the Stinger Club!
Old Apr 24, 2005 | 08:15 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
.....A great mod to start with bro......Good luck with some sunshine....
Old Apr 25, 2005 | 07:28 PM
Darion's Avatar
Darion
Dave1 and Dave68, Thanks guys, and ya, I wish it was warmer up here but this can't last forever. First mod yes not the last, Borla Stingers go on next, now if I can just find a car lift
Later
Darion
Old Apr 25, 2005 | 10:47 PM
Dave68's Avatar
Dave68
Later
Darion
Darion,
Some forum members stopped by to help me with my first mod - Borla Stingers. I bought some 6 X 6 lumbar, cut it into foot-long sections and stacked them under the floor jack. We had to lift the rear end about 31 inches and ever-so-gingerly, removed the last section of over-the-axle OEM pipe on the right side. Once this part was accomplished, we lowered the rear onto jack stands and assembled the much-lighter Borlas. We did have to disconnect the sway bar from the right side, only because the wood blocks were preventing the pipe from swinging up out of the way.
So yes, it is possible to do this mod without a lift; it's just that it IS a little bit scary when the wood is piled up on the floor jack cradle.
Dave
Old Apr 25, 2005 | 11:37 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Very pleased with my Stinger. Made my Ghl bullets sound much better also.
To Haltech Stinger install
