Best Rotors
All that money to run an team and not one single ounce of credit. Not to mention the League didn't even know your "driver" was racing the year you "owned" the team he was on.The rotors above were CAST with the holes, and guess what they still crack. and they crack bad. Makes little difference.
Again thanks for the education. But Like I said I'll keep racing on solid rotors that stop me shorter (because of added material) and don't break (Because of structural weakness from missing material). I guess I'm just old fashioned
In any case, disclosing PM information on the forum is a violation of forum rules and a moderator should take close look at this.
Get over yourself
I wish you well in life.
Alcon Slotted.
http://www.alcon.co.uk/frameset.asp
Stoptech Slotted. They have ones with Holes as well.
http://www.davidfarmerracing.com/vettstuff.html
LG uses these as well on their World Chanlenge Car as well.
http://www.brembo.com/ENG/Cars/Bremb...MMaranello.htm
Hmm. Ceramic's with holes. Plain/Slotted/Holes. By the way, same ones on the Enzo & MC12.
Cheers
I just put the PFC Z rated pads on my car... do they take a couple of stops to start working right? They didn't seem to grip as well when I did my 8 minute commute to the train station this morning...
Don't come to a complete stop.
The last time should be all out, anti locks brakes on the edge of engaging... but not.
What's this?
C6Z06 Alcon's with holes
http://vorlon.case.edu/~aap8/gallery...Corvette_Mag_9
And this?
C5R Ceramic Alcon's with holes
http://www.z06-corvette.com/super/corvette-c5r-05.jpg
I think, I will rely on GM Racing and other race professionals to build my C6R, like I did my C5 Z06.
P.S. Paras,
you're welcome. Also, put about 350+ gentle miles on the PFC's before you get into them and they will completely bed properly and last a very long time.
as others have said, Drilled/slotted is bling, bling only and doesn't hold up to real abuse. Look at the T1, Speed WC GT/TC, ALMS, F1, NASCAR, CART, IRL, Trans Am, or any other race car you can think of and you won't find drilled rotors.
As long as you are still posting on this thread, I'd like to ask, again, what is it that you feel makes the NAPA/Raybestos rotors "cheap". Unless you mean "cheap" as in price, I'd like to hear where they are short in quality.
now let's compair
Drilled rotors
Solid Rotors
and if you don't like it from me, listen to an engineer that designs brake systems
This was written by forum member Mighty-Mouse
3.5 years with Foundation (first engineering job) - Rotors, Calipers, basically the stuff inside the wheel
~4 years with Actuation - Vacuum boosters, Active boosters, Master Cylinders (mostly for ESP) and adjustable pedal assemblies
A bit under 2 years with Electronic Driver's Aid Development - ABS/TC/ESP(AH in Vette speak)
just over 1 year as a Brake System Engineer (less engineering and more project management),
http://forums.corvetteforum.com/show....php?t=1024509
"Cross-drilling:
They where created to allow gas from the pads, out-gassing, to escape so it does not create a barrier.
They where never meant to be used for long, one race and in the garbage.
No modern pad out-gasses anymore until the temperature gets so high that the brake fluid stops being fluid and goes into a gaseous state.
Now the "hype" is that they improve cooling. And on a brake dyno test stand or in simulations they do somewhat. The theory being that air is drawn through the holes and out the vents.
In the real world, they don't because the air flow is way too turbulent. You turn the wheel, the car moves up and down, sideways, etc., etc.
It's old technology for an old problem.
Slotted:
Where also created for out-gassing, actually slotted rotors where invented because drilled rotors cracked so badly and so often.
Slotted rotors do have a slight benefit in the real world of "pad cleaning" which is basically scraping a very thin film off the pad. It actually does happen, but it probably has no effect on braking distances. And not worth any extra cost. For an out and out race car it's probably worth it because they can use every little 1/1000 of a second.
Slotted rotors will increase pad wear noticeably."
"Real world experience, well thought out reasoning and engineering know-how is no match for Madison Avenue
Point in case, one of my fellow club members (BMW CCA) when I lived in Michigan also insisted that drilled rotors where much better.
After showing him data that showed the exact opposite he responded by saying, "Well the engineers at Porsche and Ferrari use them and they're a lot smarter than anyone at your company."
The company was Continental-Teves (aka ITT-Teves, aka Ate Brakes).
It was almost as if I had questioned his religious faith.
Here's the crust of most research done on perforated rotors:
The drilled rotor was actually cooler, but not because it dissipated heat better. But because it could not retain heat as well as a solid rotor.
The pads, brake fluid, caliper housing and wheel bearings all showed a marked INCREASE in temperature with perforated rotors.
The perforated rotor is the equivalent of mounting a smaller rotor with the increased possibility of cracking.
In the system, and that's what matters, the temperatures are HIGHER with perforated rotors as compared to a solid rotor.
That means early on set of brake torque loss (fade), lower friction levels over the temperature range, more frequent brake fluid bleeds and increased wear.
So, when some people say, "Drilled rotors are cooler." It's like saying that a V8 with 2 cylinders down runs....technically it's not a lie..but it really is mis-leading.
A good rotor absorbs heat, holds it until the air pump that is the vented rotor can dissipate that heat away from the vital areas radially outward.
When you remove mass from a rotor you effectively decrease the ability to absorb and hold heat and the heat radiates out in all directions, just like an old fashion radiator in a house, directly effecting nearby components.
This is why you rarely if ever see a non-vented rotor on the front of a car. The car would reach terminal fade in no time without some big, heavy disk.
This is also why cooling ducts are so effective, if they are placed correctly.
The perforated rotor also shows obvious signs of uneven surface wear and pad compound laying due the different rates of heating and cooling over the surface of the rotor.
Pad wear life was reduced by at least 5%.
Even the most mundane brake pad will not gas until very high temps today. And some pads will not gas at all, they'll go "slippery" (less than 0.15mu coefficient of friction) and there's nothing any rotor can do to help that.
You'll more likely lose brake pressure due to boiling fluid long before that.
FYI - The steel backing plate will give you 0.20-0.25mu
If your pads out-gas bad enough to effect braking, then you need to stop being so cheap and spend a few extra bucks on the good stuff or at least the mediocre stuff.
If you think about what has been posted in this thread from most of the posters, you'll realize that it's actually basic common sense.
Believe people that have real world experience and technical training with no stake or believe the hype."
and here are some pictures from that post
CTS-V
AP racing on the SunTrust car
Performance Friction Brakes
Hardbar's race car
or you can go to Wilwood's site and find this under their FAQ
"Q: Why are some rotors drilled or slotted?
A: Rotors are drilled to reduce rotating weight, an issue near and dear to racers searching for ways to minimize unsprung weight. Drilling diminishes a rotor's durability and cooling capacity.
Slots or grooves in rotor faces are partly a carryover from the days of asbestos pads. Asbestos and other organic pads were prone to "glazing" and the slots tended to help "scrape or de-glaze" them. Drilling and slotting rotors has become popular in street applications for their pure aesthetic value. Wilwood has a large selection of drilled and slotted rotors for a wide range of applications."
On top of that, Porsche specifically warns customers to keep an eye out for cracks if they track their cars. I can verify that because I used to have a set of porsche rotors on my car and get less than 500 track miles out of them with Hawk HPS pad before they cracked. Most people can get 500 track miles out of a set of Raybestos rotors using full track pads that are much harsher than HPS pads. So you tell me what is a better rotor, $600 for rotors that crack after 500 miles with street pads, or $100 rotors that crack after 500 miles with race pads.
now that all of that is on there, I think this has got to be close to the record for longest post
I have seen three structural engineering/physist/dymanic Ph'd's argue back and forth on this subject. The only conclusion I have drawn is that there is more than one way to skin a cat.
My arguement is/was is that there are a variety of brakes rotors on the track. Always will be. I think we will been seeing some water cooled brakes(Alcon), wafer thin titaninium rotors(ZMI), double rotors(GM), in the near future. I am sure that those will be even more controversial.
I have own several Ferrari's and Porsche's. I have never had any problems with the brakes or the rotors on the track.
