Smoke after start up
Old May 4, 2005 | 07:05 PM
bops90's Avatar
bops90
Default Smoke after start up
Hi,Need advice my 2000 coupe with 23,000 miles on it has a little black smoke coming out briefly after start up.Im thinking valve seals,but isnt that premuture for the milage. Thanks for any input Mark
Old May 4, 2005 | 08:20 PM
mike348's Avatar
mike348
Black smoke is not oil, its bad combustion.
Old May 4, 2005 | 08:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Could be a leakey injector or even a dirty injector. I would see if there is an exsessive fuel pressure loss at engine shut down which would indicate that the injestor/s are leaking.
BC
Old May 4, 2005 | 08:45 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Could be a leakey injector. Check to see if your loosing fuel pressure after engine shut down.
BC
Old May 4, 2005 | 08:48 PM
Shylor's Avatar
Shylor
What type and brand of fuel are you using?
bops90's Avatar
bops90
Thanks Bill,Mike That give me a direction to go.When i bought this i got extended warranty.With my c4 i hade to do it all.Thanks again
Old May 4, 2005 | 08:56 PM
jimcork1's Avatar
jimcork1
BC
A leak down test will tell you if a lifter is leaking and which one. It basically allows you to pressurize the fuel system with the engine off and monitor the rail pressure. If the pressure drops too soon (don't know the exact time) you have at least 1 injector leaking through. Then the test requires unplugging and re energizing the system to verify which one is leaking. I don't have the tools to do this test but if you can find someone who does you can pinpoint the injector or at least prove it is or is not an injectory. 99 Nassau Blue
Old May 4, 2005 | 09:13 PM
bops90's Avatar
bops90
Shell 93 oct
Old May 5, 2005 | 03:23 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Run some Techron through that baby. Shell Gas will make your gauge not work correctly. 2 Bottle of Techron will do just fine. IMHO
To Smoke after start up
