Help!!! Stripped Caliper Bolt Head
Old May 6, 2005 | 06:47 PM
Clamshell's Avatar
Clamshell
Default Help!!! Stripped Caliper Bolt Head
As I was changing my brakes and rotors this afternoon I attempted to remove the top caliper bolt on the passenger side and somehow stripped the bolt head. I am not exactly sure how this happened since I was using a 21 mm socket with a 1/2 " drive breaker bar. Could anyone tell me what I can do to remedy this problem. I am no longer able to untighten the bolt using the existing socket. I am afraid that if I continue I am going to make it worse and it will have to be drilled out . I know that it took all of my strenghth to turn it just a bit but I was able to loosen it before it got stripped. Take a look at my pics below of the stripped head and socket and breaker bar that I was using.
I am questioning whether I should have used a different shaped socket although it was 21 mm. It was a star pattern socket instead of the typical hex pattern that properly forms over the bolt head. Help would be greatly appreciated...... These caliper bolts are a pain in the butt!!!!!!!!!!!!!!
http://69.240.228.176/html/modules.p...view_album.php
TIA
Steve
Old May 6, 2005 | 07:24 PM
donnyonee's Avatar
donnyonee
try a 6 sided socket, you might have to pound it on the bolt since you muffed the head a little.
Old May 6, 2005 | 07:29 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
That is the wrong socket you are using. The bolt looks a little rashed, but not stripped. Just get yourself a 21mm hex socket (6 sides) and give it another try. Once you get it out I would recommend replacing it. Also, use either blue or red loctite on the bolt when you reinstall it.
Old May 6, 2005 | 07:34 PM
yellow01's Avatar
yellow01
What they said and a hearty lesson learned
Don't try and use a 12 point on a high torque bolt because you are only applying force on the points of the nuts.
I think you'll be ok with a good socket. You can buy an impact socket set and then you're all set to go when you eventually want an impact gun.
Old May 6, 2005 | 07:38 PM
Clamshell's Avatar
Clamshell
Well I used a six sided socket and now the bolt has broken off! I think who ever put these on at the factory over torqued them!!!!!!! I think I am going to take it to the mechanic because I am afraid to attempt to drill the rest of the bolt out myself . I am also afraid of the possibility that the other bolts will have the same problem. Any suggestions? Can I get these bolts as a seperate part from GM or do I have to buy a kit? What do you guys think? Man this has been a frustrating experience.
Old May 7, 2005 | 05:23 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you can buy the bolts from the dealer I am sure...
now..go to Sears and buy their kit for removing bolts with rounded heads...they have 2 different kits..both cost about $20.....best $40 I have spent on tools in awhile...good luck
here:
http://www.sears.com/sr/javasr/searc...=searchresults
Old May 7, 2005 | 08:08 AM
Clamshell's Avatar
Clamshell
Thanks... I might just do that... I am still debating on whether I should just take it to the mechanic since the others might have the same problem.
Old May 7, 2005 | 10:52 AM
vettenuts's Avatar
vettenuts
Make sure to get the bolts from GM. They have pre-applied thread lock and are the correct grade. You might try some heat in the area to weaken the thread locker. Good luck
Old May 7, 2005 | 11:27 AM
denscor's Avatar
denscor
Old May 7, 2005 | 03:43 PM
RCK1999's Avatar
RCK1999
There has been some great advise posted. You should try to do it yourself! Once you are successful (which you will be), then you have learned how to handle this common problem. If you need to buy some new sockets, etc, so be it. Again, then you have the hardware to handle this situation whenever it occurs.
PS - beer will also help loosen the bolts!
Old May 7, 2005 | 04:50 PM
pewter99's Avatar
pewter99
or calm your nerves after you draw blood It also attracts friends over to draw some of their blood
Old May 7, 2005 | 10:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Blue lock tite is loosened by shock. RED lock tite is loosened with heat or brute force. If you take the other bolts out and remove the caliper, is there any of the bolt sticking out??? If it is heat it up and use vise grips or better yet a pipe wrench!!
If you drill dead center in the broken off stud, heat it with a torch and drive in an easyout, it will come out!
Just make sure that you drill a big enough hole to get enough of the easy out into the stud so that you do not break the easy out. Leave enough meat in the caliper so that you dont mess with the threads
Old May 7, 2005 | 10:53 PM
IM QUIKR's Avatar
IM QUIKR
I'd like to add something here and please correct me if I'm wrong but I believe heating the parts will remove the temper or reduce the parts strength and may put you at risk in the future of failure under load. You should check on it before torching the bracket assembly.
Old May 7, 2005 | 10:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Adding heat to the stud so that it loostens the red lock tite should not hurt anything. Roasting the spindle arm until it is cherry red is not the way that it should be done.
BC
Old May 8, 2005 | 09:20 AM
vettenuts's Avatar
vettenuts
BC
If you look at the Permatex web site, they tell you at what temp the loctite starts losing its strength.
To Help!!! Stripped Caliper Bolt Head
