Need help with rear caliper removal
Old May 7, 2005 | 11:10 PM
DARKMAN's Avatar
DARKMAN
Default Need help with rear caliper removal
I got the fronts off with a breaker bar...I am concerned about the rears. I don't think I will have enough space to fit a bar in. Any suggestions? Thanks
Old May 7, 2005 | 11:13 PM
c5wolf's Avatar
c5wolf
try positioning the bar in a way that you can lower the car slowly onto the bar at a angle that will use the car weight for pressure,you have to lift it up so that you still have a jackstand for safety.
Old May 7, 2005 | 11:21 PM
DARKMAN's Avatar
DARKMAN
I will try that thanks
Old May 7, 2005 | 11:30 PM
yellow01's Avatar
yellow01
Careful using the car's weight...just for safety's sake.
Another possibility is to use a shorter bar, and a hammer. If you do this make sure it's a 1/2" drive!
Do you have a compressor?
I tell you what, a $250 compressor (was an xmas present) and an impact gun have more than paid for themselves in my garage...it makes very easy work of this type of thing. Shocks, brake brackets etc. Just an idea.
Old May 7, 2005 | 11:39 PM
c5wolf's Avatar
c5wolf
again make sure you use a jackstand
Old May 7, 2005 | 11:41 PM
DARKMAN's Avatar
DARKMAN
My CH impact gun wouldn't break the fronts loose...thats why I went to the breaker bar.
Old May 8, 2005 | 09:17 AM
vettenuts's Avatar
vettenuts
I didn't have a lot of swing room, but a breaker bar worked on my rears. Do you have the car high enough? I personally wouldn't use the car weight. Someone just broke a rear caliper bolt and is now dealing with that problem. Not to say you will have the same problem, but at least with your hands on the wrench you can "feel" is the bolt is not breaking loose whereas with the car weight it will come loose or break and you won't know until later.
Old May 8, 2005 | 10:23 AM
2001 Red Coupe Bandit's Avatar
Man I better get with it. I have had Sport brakes Slotted/Drilled rotors in a box for 2 months.
I need to get busy
Old May 9, 2005 | 10:06 AM
Andy H's Avatar
Andy H
Not a lot of room back there.
I used a 1/2 in drive socket wrench and "tapped" them lose with a mini-sledge. Not exactly precision engineering but it worked for me.
All the best!
Old May 9, 2005 | 03:00 PM
jinkikim's Avatar
jinkikim
I used short breaker bar and floor jack. It's a little bit tricky, but work very well. Put breaker bar and raise the bar using floor jack gradually.
Good Luck.
Old May 9, 2005 | 05:59 PM
IM QUIKR's Avatar
IM QUIKR
Bill Curlee mentioned that a little heat will free up the red locktite. I'd say warm the bolthead with a torch and then give it a turn.
Old May 9, 2005 | 08:00 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default 21mm wrench
21mm wr. and a hit from breaker bar or 1/2" ratchet(hold wr. and strike side w/ heavy object)there's 125 ft/lbs of tq on those from the factory, no need for heat
Old May 9, 2005 | 08:57 PM
zmans99frc's Avatar
zmans99frc
i just did mine and you need to position the breaker bar in the down position and sit behind the car and either pull it towards you with your hands or push it away with your foot, depending on what side you are doing. worked for me. did the same on the front to.
To Need help with rear caliper removal
