Caliper torque
Old May 13, 2005 | 06:08 AM
DARKMAN's Avatar
DARKMAN
Default Caliper torque
What is the recommended torque for the bolts connecting the the caliper bracket to the spindle and the bolts that connect the caliper to the bracket?
Old May 13, 2005 | 07:17 AM
yellow01's Avatar
yellow01
Caliper Mounting Bracket Bolt: 125 lb ft
Caliper Guide Pin Bolt : 23 lb ft
HTH
Old May 13, 2005 | 01:56 PM
DARKMAN's Avatar
DARKMAN
red thread lock on both?
Old May 13, 2005 | 01:58 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
No. If you want to use any, use blue.
Old May 13, 2005 | 04:22 PM
DARKMAN's Avatar
DARKMAN
all of the other threads said use red....how much trouble am I in??
Old May 13, 2005 | 04:25 PM
RCK1999's Avatar
RCK1999
The color actually depends on the BRAND. All are not the same. You want the thread-lock that does not require heat to break.
LOCTITE brands: 242 blue = temporary and removable (you want this)
271 red & 680 green = permanent and can only be removed with heat. Trust me, getting red LOCTITE brand off is a BEAR!
Old May 13, 2005 | 05:34 PM
Cajundude's Avatar
Cajundude
The post above is why. I don't think you're in trouble, it will just be more difficult the next time you take them off. If you have to take them off just heat them up real good.
To Caliper torque
