need advise, headers yes or no????
Cheers, Curt
If the car was rich before the headers it could very well be running pig rich now. And no one knows.
304 RWHP before with stock manifolds, and you have virtually the same mods I do, and you get 304 RWHP after the headers? Something is clearly wrong with that.
No offense intended, but in lieu of doing the legwork and putting forth the effort to find where the problem may lie, you seem eager to want to blame the headers. The same thing could very well have happened to you with LGs, Dynamaxx, etc.
I don't know why so many think that you can just bolt on headers, do no tuning afterwards, and consistently get good results.
It is a fact that KOOKS are on some of the quickest cars on this board. But I would bet you dollars to donuts that virtually all of those cars, mine included, has had some tuning after the header install.
Do yourself a favor, get the car looked at and tuned by someone else who knows C5s. You could have a false knock, the car could be pig rich, and on down the line. You just don't know at this point.
Appreciate the relpies so far!!!!
Terry
My 2 cents.
BC
To answer a question you had above - there is a member here that putting down 720rwhp in a convertible.
Headers : 3 main players - LGM, Kooks and Dynatech. Here's my Dynatech Supermaxx headers, high flow cats, x-pipe and Borla Stingers.
My Dynatech's cost just under $1400 complete with cats from Corvette Garage.
Here's what they sounds like - Flyby
EG
Good luck with your decision,
Darion
I have an '02 Z06 with many of the same type of modifications that you have (see my signature). The headers are definitely worth the expense.
One other thing, be sure and have a tuning done once the headers are installed. In my case the PCM could not feed enough fuel to the engine once I had increased my air flow with headers, VaraRam, 1.8:1 rocker arms, Corsa, etc. After tuning, I picked up an additional 30 RWHP.
Good luck with your car.
Resale, well I've modded almost every car I've ever owned and never had trouble with resale. Subtle mods are the key, wild paint or extremely chopy cams put off many prospective buyers.
you should not have resale problems with exhasut mods you mentioned.
